Sponsored by:
Sponsored by:
Will 4x100, 16x7 +45 rim fit
Old 12-17-2008, 08:01 AM
hanzo's Avatar
Will 4x100, 16x7 +45 our Fit?
Old 12-17-2008, 08:17 AM
BakedCookies's Avatar
with ease... I plan to push a 205/50 16" on a 16x7 +40 with the aid of camber bolts and drops springs it will just barely squeeze in.
Old 12-17-2008, 07:32 PM
the gene's Avatar
I've got 16x7 (+24mm) on all four corners on my '09... works fine with some camber.
Old 12-17-2008, 07:33 PM
kelsodeez's Avatar
UNBANABLE
hand to the face.
Old 12-17-2008, 09:08 PM
JDMchris.com's Avatar
I run THIS
i think what u ment kelso was, FACEPALM
Old 12-17-2008, 09:14 PM
kelsodeez's Avatar
UNBANABLE
exactly! hahaha
Old 12-17-2008, 10:00 PM
JDM_DOHC_SiR's Avatar
Question
Have some pic`s..??? I have got to see this on the front.. the rear might be OK but flush up front....??
Old 12-17-2008, 10:51 PM
I run THIS
i dont know if its these wheels:
or these:
Old 12-17-2008, 11:04 PM
Question
It Might be the BBS ones.. but flush.. up front ??? .. .. maybe a little poke up front... not buying it unless he has some cRaZy Camber up front..
Old 12-17-2008, 11:18 PM
bryanfor311's Avatar
doesn't messing with the camber severely effect tire wear and life?
Old 12-18-2008, 12:49 AM
victorSCP's Avatar
hand to the face.
is that a yes
Old 12-18-2008, 08:05 AM
or these:
got to be the top ones, since the bottom ones are photoshopped on, well i guess you can fit any offset in photoshop
Old 12-18-2008, 08:06 AM
yes it can, but improper toe will kill a tire a lot faster.
Old 12-18-2008, 05:59 PM
zyl8tr's Avatar
I have a +42 16x7 and I rub during hard turns. That may be because of my 205/50/16 tires tho.
Old 12-18-2008, 08:49 PM
are you using camber bolts? I plan to use them and an aggressive lowering spring to tuck in the +40's w/ 205's
Old 12-18-2008, 10:33 PM
zyl8tr's Avatar
Yes I am using camber bolts with Tanabe DF210 springs. I can only muster 0.9 negative camber.
Good luck with the +40 offset. Maybe if you go 195/50/16 it might work perfectly.
Old 12-19-2008, 10:58 AM
That sucks, too bad I already bought the tires, got those 205/50 Goodyears when they were $49 a piece on TireRack.com
Old 12-19-2008, 11:10 AM
Lightbulb
You can make them work... up front but you`ll need 2 sets of camber bolts to get in the -1.5~1.8 Range...zyl8tr only used one set and he was only able to get -.9.... so it might work..
Old 12-19-2008, 11:40 AM
So you are saying the top camber bolt would pull the hub in, then use another camber bolt on the bottom to push the bottom of the hub out more?
Subaru's had a regular bolt in the bottom, and a camber bolt in the top from the factory, that I always just set to max negative, then had an alignment done.
Old 12-19-2008, 12:51 PM
Thumbs up
Yep......
Quick Reply: Will 4x100, 16x7 +45 rim fit
