Stock HU reinstallation for GD
Old Dec 24, 2008 | 12:55 AM
FitKnight's Avatar
My Aftermarket HU just got Cuckoodoos...
Am thinking of DIYing the original stock HU.
Anyone sharing the Power suppy, Speakers Pin assignment of the connector?
Thanx in advance.
Old Jan 13, 2009 | 01:45 AM
Col. Mustard's Avatar
I'm assuming by your request that the aftermarket unit was hardwired (cut the Honda plug off), and did not use an aftermarket wiring harness? If this is the case, and you are left with bare wires, you will need to reconnect the factory harness in order for it to function regardless, and the factory harness will match up with the colors of the wires behind your dash. If the factory harness was not cut, simply unplug the aftermarket equipment and connect the plugs back to your factory unit.
Phamtastic
Mar 13, 2015 12:38 AM
vansandam
Fit I.C.E.
Jan 23, 2015 08:01 PM
Nighthawk_GD3
Dec 27, 2009 07:02 PM
g33s0n6656
Jan 13, 2009 02:12 AM
CuTeBoi
Jun 8, 2007 06:41 AM
