ANyone DIY on the fuel filter?
Old Dec 25, 2008 | 04:02 AM
FitKnight's Avatar
please help.
Old Dec 25, 2008 | 05:11 AM
joe bloggs's Avatar
Best left to a garage unless you are very capable
Old Dec 25, 2008 | 05:50 AM
FitKnight's Avatar
thanx for the advice.
Old Dec 25, 2008 | 03:38 PM
wontfit's Avatar
nonsense, consult the factory service manual.you'll need to relieve fuel pressure which is done by removing a fuse that controls the fuel pump. then crank the engine. the motor will run and then die. crank a few more times. now that the pressure is gone, unhook the rubber fuel lines going to filter. make sure you label them so they dont get mixed up or lost. remove the filter. replace. hook up the lines correctly. reinstall fuel pump fuse, and then crank engine until pressure comes back and your motor starts running. let it run for awhile and check all the hose connections for any leaks. any questions pm me.
Old Dec 25, 2008 | 03:40 PM
wontfit's Avatar
oh yeah...
you might want a rag or towel around when you unhook the fuel lines, a lil' bit of fuel might spill out. (not a lot though!) and one more thing- if you blow up your ride, i'm not responsible.
Old Dec 25, 2008 | 05:51 PM
Fit of RAGE's Avatar
i'm pretty sure it's an internal fuel filter. meaning, it's within the pump assembly, therefore, it's not replaced on a regular basis
kimo
Jan 8, 2022 12:07 PM
Santiad
Nov 30, 2011 11:43 PM
Freak In A Fit
Feb 14, 2011 12:07 AM
vic2_187
Mar 27, 2008 10:27 AM
Ed
Sep 15, 2005 10:30 AM
