Unknown Fuse Blown
Old Jan 2, 2009 | 05:16 PM
setter11's Avatar
Unknown Fuse Blown
2008 Base fit...
Which fuse would cause these problems:
Interior lights/trunk light not working
Radio not working
Power Door locks not working when car is off, but do work when car is on
Alarm not working
I pulled all of the fuses under the dash and they were all good, which one could it be?
is there any harm to pulling them all out and checking them?
Old Jan 2, 2009 | 06:46 PM
trancedsailor's Avatar
I had the exact same problem 4 months ago. Check your fuse guide, it's one under the hood called Backup. That's the one you need to fix.
And when you get a new fuse, find your radio code!
Old Jan 2, 2009 | 07:48 PM
setter11's Avatar
Re:
Thank you!!!
i will go check that in a few...
Old Jan 2, 2009 | 08:36 PM
binaryh4x's Avatar
I can vouch for the 'backup' fuse. I pulled it thinkin it was the fuse for the reverse lights... instead I got stuck with a 2hr drive home with no radio because I didn't know my security code, doh!
Old Jan 2, 2009 | 09:22 PM
setter11's Avatar
Thank You...
trancedsailor
AND
binaryh4x
Saved me a possibility of my WARRANTY being revoked....
Rep Points were added to both of you...
Old Jan 4, 2009 | 12:46 AM
reako's Avatar
Originally Posted by setter11
AND
Looks like he was desperate and started a new thread.......fuse #8 under the hood was the culprit:
https://www.fitfreak.net/forums/fit-ice/36584-electrical-help.html
tck
Aug 15, 2017 08:43 PM
oneder101
Jun 15, 2015 05:03 AM
AWDturbo
Apr 13, 2013 05:58 AM
goalie35
Dec 26, 2012 12:26 AM
Ritzbury
Oct 17, 2007 01:26 PM
