18's x 8 +32 offset...will they fit!?!?! and what tires would you recommend
Old Jan 14, 2009 | 04:31 AM
peenutz_fit's Avatar
i was pondering if the 18's x 8 wheel with +32 offset will fit on the GD3 fit? If it does, what tires would you guys recommend??? btw they are the sportmax 504 wheels...
thanks
Old Jan 14, 2009 | 04:47 AM
willitfit's Avatar
dang 18's....think those might to big but if you like them then i think 215-205/30-35 tire size would fit. you might be rubbing the inside, oh and i recomend not putting anyone in the back cause they will rub on bumps and dips.
Old Jan 14, 2009 | 08:22 AM
NBPturtle's Avatar
Are you lowered? I think either way your going to rub.
Old Jan 14, 2009 | 08:59 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
you have to pay to play haha
Old Jan 15, 2009 | 09:00 PM
bradthreee's Avatar
They wont clear the front caliper without a spacer. The back is fine. And you'll need to stretch the hell out of the tire
Old Jan 15, 2009 | 09:09 PM
solbrothers's Avatar
why wouldnt they clear the caliper? they are a LOW offset and are big rims
Old Jan 15, 2009 | 11:03 PM
bradthreee's Avatar
I'm just saying because I test fitted some 17x8 with a 33 offset and I barely had enough room to stick a business card between the wheel and the caliper
Old Jan 15, 2009 | 11:06 PM
how is that possible? just saying, that just doesnt add up
Old Jan 16, 2009 | 02:47 AM
willitfit's Avatar
^^ same with you im confused to...haha
Old Jan 16, 2009 | 07:25 AM
MarkyMark's Avatar
They fit. The rear quarter pannels need to be flared. The fronts fit fine. I'm running Toyo TR1's 205/35R18s.
The design of the spokes has more of an impact on whether or not a wheel clears the caliper.
Old Jan 18, 2009 | 02:49 PM
khanhdom's Avatar
don't spread false info
Old Jan 18, 2009 | 03:43 PM
bradthreee's Avatar
I guess it just must be my rims. Sorry for any confusion
Old Jan 18, 2009 | 04:53 PM
mahout's Avatar
Offset has very little to do with the fitment of the wheel dish over the caliper. Offset merely sets the relationship between the outer and inner wheel rim edges compared to the hub face.
The dish must be deep enough to clear the calipers. If the dish were flat there is no hope of clearing the caliper as calipers extend an inch or so further out than the hub face. There is a wide variety in the dish shape which is why even though the BC and offset are OK the wheel may not fit. The hub bore also must be matched as well.
And no; 32 mm offset is too much as well as the extra weight of 18" tires will stomp on your acceleration and mpg numbers.
If you are willing to do bodywork then you can go for it but be prepared for a drop even with such a tire as 205/35x18 even if it exists.
Old Jan 18, 2009 | 05:28 PM
mimpi's Avatar
show us the rims , they must be some kind of low disk type wheel. dishness?
Goettler
60
Jun 29, 2016 10:41 PM
Halcyon
Nov 25, 2010 07:15 PM
SikxChoi
Jan 13, 2010 02:51 AM
inxsole
Nov 4, 2009 12:55 PM
mahout
May 16, 2008 02:49 PM
