High revs (1.5 to 2K) on start up
Old Mar 14, 2006 | 08:18 AM
Moog's Avatar
I have a brand new Jazz auto 1.4 DSi. When starting it first thing in the morning the revs seem to be high at around 1.5. When I put it in drive the car is really 'creeping' fast before I even touch the gas pedal. After a few mins in seems to settle to under 1K revs when I'm stationery.
Is this normal and will it sort itself out in time? It there something I can try before going back to dealership? Thanks.
Old Mar 14, 2006 | 09:59 AM
b17gsr's Avatar
Sounds normal. An engine idles higher when cold to speed up the warming process.
Old Mar 14, 2006 | 11:25 AM
NvM's Avatar
NvM
my car does that until the blue warning light goes off
Old Mar 14, 2006 | 02:30 PM
eyemdee's Avatar
I have a late 2004 1.4i-DSI CVT Auto as well and mine is exactly the same, just for the first couple of minutes from a cold start. Just a characteristic of the way a cold engine is fuelled by the ECU during the warm up cycle. Personally I find that selecting S-econd rather than D-rive is more comfortable when setting off with a cold engine as the gear ratio is lower and it saves using the brakes so much!
Old Mar 14, 2006 | 03:33 PM
kentris's Avatar
Yeah that's fine nothing to worry about. The engine has to rev higher on idle to get the engine all warm. Make sure though when you're driving on a cold start keep it 2k and under, as the engine oil isn't viscous enough and so you won't do any damage to engine .
Old Mar 14, 2006 | 03:58 PM
Moog's Avatar
Nice one guys. Good to hear this is normal. I'll try the second gear tip :-) Thank you!!
Old Mar 15, 2006 | 03:04 PM
Moog's Avatar
Pulling away in S-econd is so much better. I'm happy! Thanks.
korgster
Jan 31, 2020 11:13 AM
chilis trip
Dec 17, 2015 12:31 PM
shivic
Mar 30, 2014 01:55 PM
BraytonAK
Feb 3, 2012 02:07 PM
BBGorson
Oct 24, 2006 10:17 AM
