Rota wheels will they fit??
Old Jan 19, 2009 | 03:47 PM
08fithappy's Avatar
Hey here are the wheels i want to get
The size is 16x7 4x100 +40mm offset 67.1mm bore would these fit on a lowered fit with progress springs??? I'm not sure i might get them in white but i love the gunmetal. And if any one is good with editing could u put those on my car so i can see how it would look thanks guys
Old Jan 19, 2009 | 03:50 PM
rvall004's Avatar
yes they will fit.....im lowere on coils and my wheels now are the same size!!!
Old Jan 19, 2009 | 04:02 PM
Fitftw's Avatar
+40 offset should work just fine. how fat is that lip?
Old Jan 19, 2009 | 04:53 PM
simply's Avatar
yessir... i got rotas on mine right now... unless... someone... has... stolen... no, i still have rotas on...
Old Jan 19, 2009 | 04:56 PM
08fithappy's Avatar
No sure i can't find where ir says any where. But guessing 3 inches. They are knock offs of these if u ask me but i can't afford these at $400 a rim. Well those are only costing me less than $500 for a setName:  152.jpg
Old Jan 19, 2009 | 05:06 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
rotas on a honda?
i dunno, i'm pretty sure it's never been done before.
Old Jan 19, 2009 | 05:10 PM
08fithappy's Avatar
LOL i was not sure about the offset wold 40 be enough on a lowered fit. But sounds like it will work
Old Jan 19, 2009 | 05:17 PM
08fithappy's Avatar
Dam i just called JLB that is who i am geting them threw they don't have the gunmetal or white in the D2 but they do have black and silver. They say the black is a gloss and looks just like the pic i have. So should i opt for those guys what do u think?? I really need some one to photo shop those on my car if they look good i will buy tonight
Old Jan 19, 2009 | 05:20 PM
just get them through tirerack or something...
but black wouldn't look bad,
and neither would silver.
and 40 offset will definitely fit, and if you have any problems rubbing it should be an easy fix.
Old Jan 19, 2009 | 05:44 PM
08fithappy's Avatar
Tirerack does not carry them. But JLb will give them to me for 489 shiped to me. Now i am going to call to see how much with wheels shiped see if i can get a good deal if i buy both together. I thought that was a good price.
Old Jan 28, 2009 | 08:53 AM
Type 100's Avatar
They'll most likely rub. +45 is the magic number for GD wheel offset
It might depend on what rubber you shod them with, though. I know a few people who have +40 offsets but can still pull it off with the "right" kind of tire...
I don't quite understand it fully, but what they're looking for is how the "shoulder" joint between the tread and sidewall is constructed. If it's a certain shape it will avoid rubbing. "Rounded" tire shoulders seem the most likely to rub.
Old Jan 28, 2009 | 01:22 PM
08fithappy's Avatar
I got the wheels in and will be installed this weekend so i hope they don't rub
Old Jan 28, 2009 | 06:45 PM
avocado123's Avatar
FALCON PUNCH!!
Um, sorry buddy but you are completely wrong. I'm lowered on Progress springs and have +42 offset rims and have never rubbed (see sig pic). The only other offset for my rims was +35... I regret not getting those
Old Jan 28, 2009 | 06:53 PM
08fithappy's Avatar
Yea i thought with a 40 mm offset or higher it would not rub. I am going on those Tr1 coils as low as i can on these rims. Should look sick i am not worried about the comfort of the ride to much. Can't wait i will take pics and post as soon as the wheels and coils are installed
Old Jan 28, 2009 | 08:00 PM
Type 100's Avatar
+42 is the bare minimum without rubbing.
But I ain't wrong. The stock GD wheel offsets are clearly +45. Stick to those when you upsize your wheels and you won't go wrong, no rubbing at all. That's why it's the "magic number." The only time you'll rub with +45 offset is with crazy widths or sick drops.
Old Jan 28, 2009 | 08:33 PM
avocado123's Avatar
FALCON PUNCH!!
:SIGH: 2 errors chief...
1. It is possible to have a lower offset than +42 without rubbing
2. The stock GD wheel offsets are clearly +55
Old Jan 28, 2009 | 11:19 PM
Type 100's Avatar
Maybe where you come from. Over here the GD1s had stock 14x5.5 wheels, clearly stamped +45. The ASEAN GD3s had stock 15s with the same offset, not sure about the width.
Over here, +40 offset wheels can get away without rubbing but they're now dependent on the shape of the tires' shoulders like I mentioned. Either be really picky with tires or run coilovers. GD311 (who's also a member here and also comes from the Phils.) runs Work Equipt 01s with +38 offset and they don't rub...only because he also runs Tein coilovers (can't remember which, Super Compact or Basic Compact). He had rubbing all over the place when he still had stock dampers and springs.
I guess the GD Fits/Jazzes on our shores are built a little differently. I thought the only differences were the longer bumpers and front-end chassis rail for US crash regs. Apparently even the "acceptable" offsets are different.
Jimboz
16
Jan 12, 2024 11:40 AM
hanzo
Feb 6, 2010 06:40 AM
mikejet
Mar 11, 2009 06:13 PM
Alan_Fits
May 22, 2006 07:53 PM
