Help! ABS Light On.
Old Jan 21, 2009 | 07:18 PM
RandomKoko's Avatar
Help! ABS Light On.
I just installed lowering springs yesterday. Then today my ABS light just turned on when I was driving on the freeway. Did anyone happen to occur this situation before? I'm getting irritated about this abs light. I tried resetting it also but it did not work. Help pls. Thanks.
Old Jan 21, 2009 | 07:22 PM
sonicsc1's Avatar
maybe you broke the sensor or its loose check them all.
Old Jan 21, 2009 | 07:29 PM
RandomKoko's Avatar
which sensor is that? sorry i don't know much about fits yet. i don't think i broke any speed sensor or abs sensor idk how can you tell if i broke it? and idk if the sensor is loose.
Old Jan 21, 2009 | 09:24 PM
Stevens24's Avatar
I'v gone through a couple of speed sensors. With mine it would reset then when I hit around 40mph it would trip the code. It was fixed under warranty.
Old Jan 21, 2009 | 11:50 PM
RandomKoko's Avatar
yea. but i installed tanabe lowering springs. and do you think they will void my warranty?
Old Jan 22, 2009 | 09:16 AM
SHG_Chiquita's Avatar
well to put in springs you had to unplug the sensors...so did you plug them back in correctly?
Old Jan 22, 2009 | 12:19 PM
RandomKoko's Avatar
yea i pllug it back correctly its weird it only happen when i started driving.
Old Jan 22, 2009 | 12:22 PM
i would go back and double check that they are plugged in all the way before I started worrying about anything else...
because it happened after you put your springs in makes me think that something wasn't attached properly when you put it back together...
Old Jan 22, 2009 | 12:57 PM
RandomKoko's Avatar
yea i double check already. and i didn't remove any plug. when removing the strut i just unclip the sensor. yesterday morning it didn't happen when i started the car and i just kept on driving to the freeway and all of the sudden boom! abs light on. idk sigh... i'll try go triple check it again. well... is there also any other causes to an abs light?
Old Jan 23, 2009 | 12:16 AM
RandomKoko's Avatar
nobody? please help. =(
Old Jan 23, 2009 | 01:37 AM
RandomKoko's Avatar
nvm problem solved. i just moved the abs wire out cause the nut from the strut was pressing down the wire. s
Old Jan 23, 2009 | 04:51 AM
doctordoom's Avatar
Supervillain
nice, you got it fixed. it makes sense to check what you did if a problem arises right after a modification.
EggHead
Nov 11, 2016 08:21 PM
jdDC
Dec 30, 2015 02:52 PM
RandomKoko
Jan 30, 2009 05:18 PM
RandomKoko
Jan 27, 2009 10:49 PM
untx3
Aug 16, 2007 02:29 PM
