wheel mixup
Old Jan 31, 2009 | 04:57 PM
xpoxpo's Avatar
wheel mixup
i took the front 2 wheels off my fit to paint them black, but i forgot label them... so i don't know which one goes where. my plan was to paint all 4, rotate the fronts to the back and vise versa... i was told that since they are weighted they have to go on their original side...
any input on this?
Old Jan 31, 2009 | 05:36 PM
Super Mario's Avatar
If I was in your situation I would just say screw it since you're rotating them anyway. Just put the fronts to the back and be sure to remember which rear wheels are which so you can criss-cross them to the front.
I've never heard of the weight on the original side thing. Each wheel/tire has weights on them in order to balance them, but they're not specific to which side of the car they go on. GL!
Old Jan 31, 2009 | 05:40 PM
moegenki's Avatar
Check the outside tread if they are channeling outwards relative to the rotation and see if you can differentiate the two.
Old Jan 31, 2009 | 05:43 PM
xpoxpo's Avatar
thanks man, i was thinking the same thing about the weight
Old Jan 31, 2009 | 06:01 PM
solbrothers's Avatar
wtf? weighted?
Old Jan 31, 2009 | 06:07 PM
xpoxpo's Avatar
wtf? weighted?
the wheels have stick-on weights on the inside, for balance
Old Jan 31, 2009 | 06:11 PM
omg. LMFAO!!!!!!!!!!!!!!!!!!!!!!!
the wheels arent balanced ON your car. they are balanced on a machine. they are balanced to themselves. you could put your rim on my car, and itll still be balanced. doesnt matter left, right, up or down
Old Jan 31, 2009 | 06:15 PM
wait4thefit's Avatar
yea it does i just got my tires mounted and balanced today on my new wheels and they labeled them. they label them so you have a more comfortable ride
Old Jan 31, 2009 | 07:13 PM
xpoxpo's Avatar
yeah man.. that's what i thought, i just wanted input because people IRL were saying they are balanced for the side
thanks though
Old Jan 31, 2009 | 07:14 PM
lmfao!!!!! whawt are you talking about?
MAYBE you mean the tires are directional. but theres no way that a tire would be "balanced" for the front right, or front left, etc etc position. that is bullshit
Old Jan 31, 2009 | 07:16 PM
thanks though
no problem. check your tires. they might be directional. a balanced wheel is a balanced wheel, but your tires could be directional meaning they are supposed to be on the left, or right side depending on how they were mounted on the rims
Old Jan 31, 2009 | 07:24 PM
alright...
Old Jan 31, 2009 | 07:29 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Actually, some people do whats called "Road Forcing." I did it when I worked at Dodge/Jeep. You road force the tires and wheels. It puts a big drum (simulates the road) against the tire and adds lots of pressure.
After its done it comes up with a number on the screen. Anything higher than 25-30lbs of road force will result in real low speed AND high speed vibrations.
So, if you have this type of reading; 10lbs, 4lbs, 20lbs, 23lbs, youre suppose to keep the lowest numbers closest to the driver.
4lbs...10lbs
20lbs..23lbs
Thats how it would sit on the car.
Other than that, Matts right. People RARELY road force tires/wheels. I only did it so that I wouldnt get any complaints. It also points out bad tires and bent wheels.
Old Jan 31, 2009 | 07:30 PM
wtf haha. i gotta ask my tire hookup guy about that
Posts in the NUUDE
Yours were probably road forced... And I believe your tires are directional.
So I noticed from the tread.
Old Jan 31, 2009 | 07:33 PM
yea im pretty sure they were road forced. and yes my tires are directional.
Old Jan 31, 2009 | 11:29 PM
xpoxpo's Avatar
thanks for the input everyone
Fit2009BaseAT
Nov 25, 2014 02:49 PM
SSR Wheels
Nov 24, 2014 01:01 PM
Bama3Dr
Aug 21, 2014 11:59 AM
jnesselroad
Mar 12, 2011 11:28 AM
YeeFit
Car Shows, Events, and Racing
74
Jul 21, 2009 06:57 PM
