Retro --> what to do with Fogs?
Old Feb 3, 2009 | 04:23 PM
Canadian_R32's Avatar
For those that have done a retrofit on their Fit what did you end up doing (if anything) with your fogs? throw in brighter bulbs? different colour bulbs? threw in a PnP HID kit?
I'm looking to get Retro's done real soon and have this dilemma... maybe my fogs won't even be used period.. not sure...
Old Feb 3, 2009 | 05:36 PM
xonexlifex's Avatar
get some hids for the fogs, i love the way the fits look with the yellow film and 3000k hids, the fogs will help still even with retrofits so the more light, the better!
Old Feb 3, 2009 | 06:01 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
that's what he said...... I have retro and 3000k hid with yellow film on the fogs BRIGHT!!!!!!!!!!!!!!!!
Old Feb 3, 2009 | 07:40 PM
mholbrook38's Avatar
Why not try this.....Fog bulbs stock are H11. Change to H9 for about a 40% increase in light. H11 is a 55w bulb producing 1350 lumens. You can substitute an H9 bulb, 65w producing 2100 lumens with very little modification.
Basically, you have to remove a piece of the plastic in the connector with a razor knife. The indexing tabs are nearly identical but you might want to trim off a couple mm if you have a problem with the install. The two "lower" tabs are the same. The single upper tab is slightly different. If you put the upper tab into the slot and turn very slightly, the lower tabs just pop right in. There is a small tab of plastic on the actual light socket that might need to be relieved with the razor knife.
Cheap and very effective. Something I did on my 2007 Pilot.
Mike
Old Feb 4, 2009 | 03:51 AM
ghettoboy247's Avatar
or u can jes get hid fogs that use less energy so you don't accidently "burn" your foglight film!!! HID's ftmfw!!!
Old Feb 4, 2009 | 10:33 AM
question for those that did the film and 3000K... isn't 3000K already yellow? or does the film give the "ultimate JDM look" .... anyone able provide pictures with the retro and the hid fogs? both dead on and cutoff's?
Old Feb 4, 2009 | 10:59 PM
xonexlifex's Avatar
the 3000k hids are yellow but since they are sooo bright they look more stock color looking infront of them but on the ground its yellow, 3000k hid fogs with the film is the way to go, brightest you can get with having film and not burning through, i found the hids to be more helpful than stock ones bec the stock h11 bulbs have a weird cutoff and the hids are lower and wider cutoff, it just looks right with hid headlights thats all i know, i couldnt be any happier with my setup.
this is the best i can do
Old Feb 4, 2009 | 11:35 PM
appreciate the pics.. but I'm guessing my setup would look similar to Bitoy's? since he has the retro's....
Old Feb 5, 2009 | 12:38 PM
NIGHTHAWKSI's Avatar
my retrofit has 6k ultinon bulbs in FX projectors. and my fogs have yellow 3k halogen bulbs.
but i will be getting rid of my fog lights soon, so if anyone wants some VERY yellow fog light bulbs with low hours on them, PM me.
Old Mar 12, 2009 | 04:52 PM
BUMP.... on the verge of starting this project... just wanted to make sure getting HID's for the fogs is still the way to go... since the bumper is already off for the retrofit labour will be "free" anyways... anyone with the setup I'm looking for with pics?? anyone??
Old Mar 12, 2009 | 07:03 PM
FELIXY69's Avatar
i LOVED my HID fog when i had it.....but now that i don't have fog lights...i hate looking at other cars with it...cuz it's too bright....it pisses me off...
either that i am just jealous that they have it and i don't...either way..i don't suggest it...but it's bright
Old Mar 12, 2009 | 08:11 PM
713_fit's Avatar
wow so a lot of people do have hid yellow bulbs with yellow film
i was considering during that but wasnt sure if it was going to affect the light output
does it affect the light output?
i currently have yellow 3000k hid bulbs in there
i want the yellow look in day time too
Old Mar 12, 2009 | 11:18 PM
it's too bright it pisses you off??? why? I don't get it, you're jealous that they have it and you don't, yet you don't suggest it?
Old Mar 12, 2009 | 11:19 PM
do you have HID's for your regular bulbs too? if so do the fogs "over power" the head lights in anyway? or is the cutoff completely separate?
Old Mar 13, 2009 | 02:43 AM
713_fit's Avatar
yeah i have HIDS in my regular headlight location
4300k low beam
3000k foglight
the fogs does not over power at all, if i park in a straight road, the headlight shine way farther and away from the foglights, the foglights light the area in front of my car with bright yellow.
cgpEJ6
Jul 31, 2010 11:44 AM
xonexlifex
Jul 15, 2010 04:04 PM
Santiad
Nov 25, 2009 09:00 PM
marcryan27
17
May 25, 2008 10:49 PM
gn-it&rn-it
Aug 1, 2007 02:08 AM
