Question about the rear garnish?
Old Feb 16, 2009 | 11:59 PM
Nigh-T Pedri's Avatar
I got a question and may be I didnt asked it correctly but I need help about it.
How do you remove the rear garnish? were the H emblem is at?
Old Feb 17, 2009 | 12:05 AM
fitster's Avatar
you have to take the rear panel off and go from the inside
Old Feb 17, 2009 | 12:07 AM
ok, but is there some specific on the panel that lets you take it of? Because I dont wanna rip it off and break something you know.
Old Feb 17, 2009 | 12:15 AM
Fitcapo's Avatar
You have to take off the entire interior panel of the hatch. Then there is 1 bolt on the left side on the inside of the hatch if you are looking up at it. You also need to remove your wiper motor so you can reach one of the 4(maybe 5) clips you squeeze and push up to pop the panel off. It is really easy and hard to mess up. The only part you really need to be careful with is pulling off the interior hatch panel because I accidentally broke the little plastic handle that is attached the rear panel by pulling on it a little too hard.
Old Feb 17, 2009 | 12:17 AM
I know what part you mean. I broke it too not long ago. Warranty covered it up. Thanks for the info.
Old Feb 17, 2009 | 12:18 AM
Fitcapo's Avatar
If you want I was about to do a quick photoshop of the pic you posted up to let you know where the clips where on the inside just to help you know where to look.
Old Feb 17, 2009 | 12:20 AM
Alright dude. Thanks
Old Feb 17, 2009 | 12:26 AM
Fitcapo's Avatar
sorry forgot to resize pic on imageshack so it will be a little big.
the green dots are the clips that you can just squeeze and push them through. The pink dot is the bolt and the yellow shape is roughly the wiper motor. The wiper motor has 3 bolts on it then it comes off. Well after you take the wiper off. To get the wiper off you pop off the little cover right near the base of the wiper and there is just one nut that comes off and it will come right off. I believe all of the nuts and bolts are 10mm.
Old Feb 18, 2009 | 12:04 AM
Alright bro. Thanks for the info. I'll see if I can work on it some time during this week. I'll keep you posted if I have any problems or doubts
FunkTastic
Oct 28, 2020 07:31 AM
gnuman05
Dec 29, 2012 04:55 AM
peg_leg
Feb 7, 2009 06:25 PM
Marsha61Fit
Jun 18, 2008 03:27 PM
smatts
Jan 9, 2008 09:07 PM
