Paddle Shifters
Old Mar 29, 2006 | 02:23 PM
hen88's Avatar
Paddle Shifters
Sorry for my ignorance, but what exactly are Paddle Shifters? I probably going to get a Fit Sport, and I'd like to know what they are exactly.
Thanks.
Old Mar 29, 2006 | 02:38 PM
HashiriyaS14's Avatar
They're little buttons that you hit with your thumbs to electronically shift up or down on the Fit Sport 5AT.
It's a vague approximation of an F1-style sequential gearbox, which uses wheel-mounted paddles (but they are true sequential manuals, as opposed to the electronically-actuated automatic tiptronic on the Fit).
In short, it allows you to keep the car in the powerband, to downshift earlier than the automatic would normally. This helps when entering a corner, as the car won't bog down low in the powerband forcing you to rev back up to make power, you'll be able to keep it within 2-3k rpm of redline all the time. It will also help slow the car vis-a-vis the engine braking, which is nice for slippery conditions, as it makes all the difference sometimes between avoidance and collision, IMO.
Old Mar 29, 2006 | 10:43 PM
hen88's Avatar
Thanks. I kind of get it now. But I'm still a bit confused. I'll have the dealer explain it to me when I buy the car. Thanks again.
Old Mar 29, 2006 | 10:48 PM
Titans's Avatar
Confused
I have the same problem as well and not sure whether to get the Manual or the paddle shifter, after I did some research and asked several expert.
I concluded to get the manual and save $1300
Paddle shifter is not as fun as the manual.
Hope this help
maui
Aug 15, 2014 11:03 AM
ikutoisahobo
May 12, 2014 02:10 PM
jazzivtec
Apr 19, 2013 11:50 AM
sumtingwong
Oct 27, 2010 10:53 PM
stevet47
Jul 2, 2009 11:46 AM
