Maintenance letters = what mileage?
Old Feb 28, 2009 | 08:34 PM
kinosh's Avatar
Does anyone know the approximate mileage for each of the maintenance letters? I've been changing my oil whenever the maintenance reminder lights up without really looking at the letter. Now that I'm up to 30,000 miles, I probably should be doing more, like changing the air filter. I know A = 7,000 miles. What's B, C, D, E?
Old Mar 5, 2009 | 06:58 PM
ShaggyiFit's Avatar
There is only an A and B and they just mean change the oil. When it comes with the numbers 1-5 that means other things.
Example: A12 - Change oil, rotate tires and change engine and cabin air filters.
Its all in the fits owners manual.
Old Mar 5, 2009 | 08:05 PM
kinosh's Avatar
I want to be able to convert those letters and numbers to mileage. I haven't been paying attention. Whenever the little wrench light goes on, I change my oil and nothing else.
Old Mar 5, 2009 | 08:10 PM
ShaggyiFit's Avatar
They do not convert to miles at all, they determine which Letter and Number appears by how you drive the car. If you drive it in a rough way the maint. minder will come on more often, you should be doing maint. according to what numbers appear, not just an oil change.
It says all of this in your owners manual.
Old Mar 5, 2009 | 09:11 PM
Stevens24's Avatar
A= Replace engine oil
B=Replace engine oil and filter
Check front and rear brakes
Check parking brake
Check following items:
-Tie rod ends
-Suspension components
- Drive shaft bolts
-Brake lines and hoses (including ABS)
- All fluid levels and condition of fluid
-Exhaust System
-Furl lines and condition
1=rotate tires
2=Air cleaner, Cabin filter check drive belt
3= Replace Transmission fluid
4= Replace spark plugs and inspect valve clearance
5= Replace engine coolant
Hope this helps
Old Mar 5, 2009 | 10:03 PM
spreadhead's Avatar
I've got 53K (miles) on my Fit. The only code I have gotten other than oil and filter and tire rotation was, as the Fit approched 30K, I got code 2, air filters and check belts.
Old Mar 6, 2009 | 10:11 AM
kinosh's Avatar
I have the manuals, I just haven't been paying attention to the codes like I should. Seems like there should be mileage equivalents to those codes for normal driving, or at least a way of downloading the code history just in case you miss something.
Old Mar 15, 2009 | 01:08 PM
HizzyFit's Avatar
How can you reset the codes yourself ?
Old Mar 15, 2009 | 03:45 PM
trancedsailor's Avatar
10k miles and B1 just came on.
Old Mar 15, 2009 | 04:51 PM
HizzyFit's Avatar
yea 10K and B1, I changed oil and filter, checked brakes and all fluids.Now I want the oil life to reset. I reset it on the last oil change with no problem but now that it shows B1 It will not reset the normal way
Old Mar 18, 2009 | 08:31 AM
spreadhead's Avatar
It's all explained in the little book that comes with Fits.
Jensen Healy
Aug 2, 2017 12:59 PM
Brisscoe
23
Jul 31, 2014 09:33 PM
tubadude
Apr 24, 2013 08:49 PM
tietack
Aug 24, 2010 01:55 PM
Bounty Hunter
Feb 20, 2007 02:00 PM
