Need help installing HID kit.
Old Mar 28, 2009 | 01:16 PM
kroze's Avatar
I bought the 55w HID kit that's not plug & play type. From the picture below, I need to know which one is positive & negative so I can tap into the wires....can someone tell me?
Old Mar 28, 2009 | 02:34 PM
theloxmyth's Avatar
Fit Gadget Freak
I'm looking in the 2007 manual and all I see is red and red/yellow feed in and red/white is lo while red/blue is hi...
Old Mar 28, 2009 | 02:38 PM
jagass's Avatar
You've done a wrong purchase....lol
Old Mar 28, 2009 | 02:43 PM
theloxmyth's Avatar
Fit Gadget Freak
I'm disappointed...
Your comment is not helpful.
Old Mar 28, 2009 | 06:49 PM
daniel123588's Avatar
The black wire is obviously ground. Get a simple voltage tester to see which wire runs postive when the headlights are turned on and than you can figure out the rest. those voltage tester are like 8 dollars. Also since your running a 55w HID system (which isnt a good idea since you dont seem to know how to even figure out which of the three wires are which, no offense) I hope you are running relays to draw current from your battery. Also i hope you are running some kind of retrofit projectors as well. People on this forum in particular really need to do some research before buying certain products. Anyway good luck with what your doing.
Old Mar 28, 2009 | 07:02 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
Black is ground white is high and orange/red is low.. if it doesn't work try switching the white and orange/red..
Connor Keyser
15
May 1, 2016 02:44 AM
orange2007vafit
19
Aug 18, 2012 02:04 PM
John16
Jun 2, 2010 12:58 PM
m-man@sbcglobal.net
18
Feb 14, 2008 09:13 PM
danger69
Jan 5, 2008 12:56 PM
