Can't Find RPF1's +35mm
Old Apr 25, 2009 | 09:10 AM
HB1320's Avatar
I want to place the other off my wheels in about a week but I cant find 15"x7 with a 35 offset all I find is 41 offset. can anyone help me and give me a direct link.
I want 15'' Enkeis RPF1 Black with a +35 offset, Thanks
Luis
Old Apr 25, 2009 | 11:36 AM
Sugarphreak's Avatar
Push My Button
41 offset is better for the Fit; +35 is just going to exacerbate the clearance problems.
Originally Posted by YeeFit
Just looking to get a new set of tires next spring...
I'm currently rolling on Enkei RPF1 15x7 +41mm offset wheels. The rubber I am using at the moment are General Exclaim UHP 195/55R15.
I need something that has more traction.. I don't really rub anymore (i did for a bit til I did some fender work). And I am not as low as before after swapping my Tein springs for the J's/Showa suspension kit.
I was going to try 205/50R15s in the Toyo T1Rs, but I noticed that they sell these tires in a 205/45R15.
I think I may run into a bit of a rubbing issue if I go with the 205/50, but maybe, just maybe I could run the 205/45s without any problems.
I know that running the 205/45 will throw my speedo off by about 3mph slower at 65pmh. But that is ok by me.
So, given the offset of my wheels, do you guys have any input on which size to go with? 205/50 or 205/45?
Old Apr 26, 2009 | 10:50 AM
HB1320's Avatar
I want +35!! bump
Old Apr 26, 2009 | 01:56 PM
User Name's Avatar
Call me on Monday @ 904-821-0982 and I'll check to see what's available in the Enkei warehouse....I've got the hookup if they're there.
Old Apr 26, 2009 | 08:36 PM
08FitSport's Avatar
Luis
Tire rack got them.
Enkei Racing RPF1 Bright Silver Paint
Someone made a big stink so they pulled them off the Fit list. (note you will have to bend the fender to bumper tabs up and better to stick to 195/55 or smaller.) Looks aren't everything be safe.
Old Apr 26, 2009 | 10:45 PM
HB1320's Avatar
I've gone on Tirerack before just you cant choose the offset only thing I see their is +41 I dont see +35
Old Apr 27, 2009 | 02:27 AM
Tork's Avatar
What the above poster is saying is, Tire Rack does have the +35
....they are just not showing them as fitting the FIT, cuz they dont really.
+35 has a lot of potential to rub, doesnt give you a lot of tire or lowering choices.
AND YOU WILL PROBABLY EAT UP WHEEL BEARINGS A LOT FASTER
So Tire Rack does have them, they may not want to sell them to you (or better said, they may try to talk you out of that choice)
You will just have to insist you want them and you will take full responsibility with fitment issues.
Old Apr 27, 2009 | 02:39 AM
Tork's Avatar
Buy them from member User Name in post 4
..But HB 1320 gave you a link right to the Tire Rack page mang!!!!!!!
On the TR site,
plug in 1996 Mazda Miata and you will see them
IF YOU PLUG IN HONDA FIT YOU WILL NOT SEE THE +35 ONLY THE +41
How to View on Vehicle Click the size you would like to see on your vehicle
Front and Rear Fitments
15x7 15x7
Original Price:
Now 0% Off:
$0 (each)
$199
$199 (each)
Price:
$0 (each)
See price in cart
Offset: +35mm Backspacing: 5.31" Bolt Pattern: 4-100
Rec. Tire Size:195/50-15
Weight: 9.9lbs.
Old Apr 27, 2009 | 03:04 AM
jagass's Avatar
No one with 35...lol
Old Apr 27, 2009 | 07:10 AM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
mines are +35mm and theybare from tire rack ...
Old Apr 27, 2009 | 01:04 PM
racecarshots's Avatar
Old Apr 28, 2009 | 03:08 PM
tougerunner86's Avatar
Plenty of people are running lower offsets nowadays, don't listen to the naysayers. I'm about to put +32 ssr vienna's on mine...hehe
Old Apr 28, 2009 | 03:44 PM
Push My Button
What tires & camber are you running just out of curiousity?
You have to call them directly to order wheels that fall outside of safe tolerances for your vehicle... that way if it rubs badly when you get them you basically wave your right to return them because "they told you so".
It would be nice if there was a way to search rims directly on Tirerack instead of by "safe tolerance".
There are people out there that have no problem running insane camber and rolling fenders, as long as they understand the risks I think you should be able to buy whatever you want.
Old Apr 28, 2009 | 04:05 PM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
^^they are 195/50/15 +35mm and i dont have camber kit on jet...
ps: i dont rub
Old Apr 28, 2009 | 04:07 PM
ChrisG's Avatar
I have 16x7 +33 RPF1's. If you want the wheel, you WILL have to call Tire Rack directly. You cannot get them in the offset you want.
Old Apr 28, 2009 | 04:55 PM
Push My Button
ps: i dont rub
Dropped at all?
lol, are you sure they are not +41?
Old Apr 28, 2009 | 05:51 PM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
tru that
Originally Posted by Sugarphreak
Dropped at all?
yeah im on skunk lowering springs...
no sir they are +35
Old Apr 28, 2009 | 09:25 PM
HB1320's Avatar
Thank you Bori I knew I had seen someone in here with them! also thanks to TORK for that info!! lol Im on T1R springs and on top of that their cut to my taste! so I hope I dont have a problem I would like to try some +35 on before I place my order, now in the summer
Old Apr 28, 2009 | 09:53 PM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
^^no problem dude, just make sure you call them and tell them what you want.
Old Apr 28, 2009 | 10:13 PM
HB1320's Avatar
here is my car you think ill have a problem?
ps: I got spacers all around
