Skunk2 Honda Fit head porting DIY
Hey everyone,
In an effort to further educate enthusiasts, Skunk2 has recently posted up another how-to video. Follow along as Skunk2 owner and founder Dave Hsu shows how to port the GD Fit’s cylinder head. Find out how much material to remove, where to remove it from, and what tools to use. Cylinder head porting has long been used as a method of increasing the volume of air that can be introduced into the cylinders. But the process is time consuming, tedious, and can often lead to undesirable results. Avoid the pitfalls, watch the video, and make more power.
See the video here: Skunk2 Racing: HONDA FIT CYLINDER HEAD PORTING
I have ported a few motorcycle heads, believe me a removing a little bit of metal is a lot better than taking out too much.... There will have to be some second hand heads available and a stand by ride before I do it to my Fit.... I still have the die grinder that I did my old Harley's heads with 20 years ago, but it was very easy with big ports, valves, plenty of metal and lots of room.... You need to think more about flow velocity rather than volume, unless you are going to be driving at high revs and have a close ratio gear set.
I would suppose that what Skunk is instructing as a porting job is really more of a light clean up job that wouldn't add that much of a power gain to an engine in relationship to the gains to be had with installing a super charger ..... Racers are a breed that will completely disassemble the engine of a brand new car in order to take every measure that is possible to gain an edge.... They will use all kinds of tricks that win will put them over the finish line first, or shave a fraction of a second off of a timed event. They can afford to spend the time and money and therefore mess up and start all over with new parts paid for by sponsors or customers purchasing their products.....Winning races is done by doing a whole lot of little things to your vehicle that you hope the other guy doesn't know about, sometimes going so far as to break the rules and in a lot cases, shorten the life of the vehicles engine and break parts....
skunk2.com
34
Jan 22, 2009 03:14 PM
skunk2tony
19
Feb 15, 2008 02:35 PM
