Cabin filter location?
Old May 24, 2009 | 02:31 PM
quick92ciFit's Avatar
I was just wondering if the cabin filter is located in the same place as the GD's?
Shown Here: https://www.fitfreak.net/forums/fit-...placement.html
Also is the fuel filter located in the gas tank as well on the GE8?
Thanks
Old May 24, 2009 | 02:36 PM
Uncle Gary's Avatar
Yup, the filter is in the exact same place on the GE. I've had mine apart already out of curiosity. It takes less than a minute to remove it. Servicing is the same as those instructions you linked to.
Old May 24, 2009 | 02:40 PM
Uncle Gary's Avatar
I checked the service manual. The filter is in the fuel tank, and is assembled to the fuel gage sending unit and fuel pump. This is one complicated little car.
Old May 24, 2009 | 03:50 PM
JPGC's Avatar
Are you sure about the fuel filter? While installing my PRM intake (AT), There is what looks to be a fuel filter on the diver's side of the engine bay toward the back, above the transmission, under the factory airbox. I haven't looked it up so I may be wrong and if I am, are you able to tell what I'm refering to is?
Old May 24, 2009 | 04:33 PM
Uncle Gary's Avatar
I looked up "fuel filter replacement" in the '09 service manual, and that's what the manual shows. Can you show me a picture of what you're looking at?
Old May 24, 2009 | 07:35 PM
JPGC's Avatar
Here is a pic. It is right under the PRM intake between the red positive terminal cover and the little green connector in the picture.
Old May 24, 2009 | 08:23 PM
Uncle Gary's Avatar
I can't find that part on my car (the stock airbox is in the way). I can't say for sure, but that looks like a vacuum switch of some sort.
Old May 24, 2009 | 08:49 PM
bigmitch's Avatar
Does the GE's use the same cabin air filter as the GD's. If so I can get them allot cheaper through FIT cabin air filter for a 2008 HONDA $7.1 then what the dealership is charging. They are quality filters as I use the same brand in my Tacoma.
Old May 24, 2009 | 09:28 PM
Thanks for the replies.
I looked up the part #'s at bernardiparts.com and they are different for the GD & GE8.
kimo
Jan 8, 2022 12:07 PM
smokieide
Jun 30, 2012 08:03 PM
Freak In A Fit
Feb 14, 2011 12:07 AM
kurtdesch
Dec 3, 2007 06:07 AM
iceman888uk
May 4, 2006 01:22 PM
