Tech Bulletin about windshield molding
Old Apr 22, 2006 | 11:59 AM
Squid's Avatar
Tomh mentioned this in another thread. I'm pasting it in this new thread to focus more attention on it:
Originally Posted by Tomh
I little more info on this so-called recall, which we other Honda employee's really call a technical service bulliten ( recalls are for safety concerns, not potential technical issue's taht may arise on few models after the initial release). Anyways, about the technical service bulletin, there is a wind noise taht comes from the upper front wind-shield molding area not being properly secured to the body, thus is could have also caused a waqter leak if let un-toucehed over a little time, honda had found this issue a day in advanced and advised all dealer to how to fix the problem before they can sell teh vehicles! Thus meaning this is not something that new owners have to worry about, the thread started forgot to or just didn't care to tell teh full truth about this, just mainly to state how ugly he thinks the car is.
I just checked my windshield molding, and there appears to be a gap between it and the glass on the driver's side. I haven't noticed any wind noise, so I guess it's possible my dealer already fixed it, but I'm going to check anyway. When was this tech bulletin issued?
Old Apr 22, 2006 | 12:05 PM
Tomh's Avatar
Senior Member
give me a few to log in to honda IN and i'll let ya know.
Old Apr 22, 2006 | 12:17 PM
Tomh's Avatar
Senior Member
Sorry it took forever, had to find a way to get it onto here, basically had to save file to my pc, load onto the site i mod, and jsut link straight to the file from here, but hopefully this should help, i can print the real deal off of IN and post here to if need more info, which would atleast have the pics also.
http://www.clubcivic.com/board/attac...chmentid=21197
Old Apr 22, 2006 | 07:03 PM
Squid's Avatar
Tom,
The website is asking for a username and password to view the file.
Old Apr 22, 2006 | 08:09 PM
Tomh's Avatar
Senior Member
Service Bulletin
CUSTOMER INFORMATION: The information in this bulletin is intended for use only by skilled technicians who have the proper tools, equipment,
and training to correctly and safely maintain your vehicle. These procedures should not be attempted by “do-it-yourselfers,” and you should not assume
this bulletin applies to your vehicle, or that your vehicle has the condition described. To determine whether this information applies, contact an
authorized Honda automobile dealer.
April 20, 2006
06-019
Applies To: 2007 Fit – From VIN JHMGD3....S000001 thru JHMGD3....S008480
2007 Fit: Wind Noise at the Top of the Windshield
SYMPTOM
Wind noise may be heard from the top of the
windshield at highway speeds.
PROBABLE CAUSE
Due to variations in windshield placement, airflow over
the windshield molding may cause it to vibrate.
CORRECTIVE ACTION
Fill the channel above the upper windshield molding
with silicone sealant.
REQUIRED MATERIALS
3M Black Super Silicone Sealant:
3M P/N 051135-08662
(One tube repairs three vehicles.)
3M General Purpose Adhesive Cleaner:
3M P/N 051135-08984
(One container repairs six vehicles.)
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Operation Number: 831004
Flat Rate Time: 0.5 hour
Failed Part: P/N 73150-SLN-003
H/C 8325664
Defect Code: 00401
Symptom Code: 00101
Template ID: 06-019A
Skill Level: Repair Technician
Out of warranty: Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starting work.
REPAIR PROCEDURE
1. Look at the upper, right-hand corner of the
windshield for a small round sticker. This sticker
was applied at the port to indicate that the vehicle
has been inspected, and a repair is not required.
• If the vehicle does not have this sticker, go to
step 2.
• If the vehicle has this sticker, the vehicle is OK,
and no further action is required.
2. To protect the paint, apply a 2-inch strip of masking
tape to the roof next to the edge of the upper
windshield molding.
2 INCH MASKING TAPE
2 of 2 06-019
3. Cut off the tip of the 3M Black Super Silicone
Sealant tube applicator at the first groove. Lightly
file the outside diameter of the applicator tip so that
it barely fits into the gap between the molding and
the roof.
4. Using a plastic card (credit card or something
similar), pull up the outer edge (lip) of the molding
at the middle of the windshield. Working toward the
side of the windshield, fill the entire channel under
the molding with the sealant.
5. Move to the other side of the vehicle, and then
repeat step 3.
6. Lightly push down on the molding to smooth it out
and form an even seal.
7. Wait for 5 minutes, and then remove the masking
tape.
8. Using a shop towel and 3M General Purpose
Adhesive Cleaner, clean off any excess sealant.
Cut off the first segment
of the applicator tip.
Start at the middle and work outward.
MOLDING
SEALANT
Old Apr 22, 2006 | 09:44 PM
Squid's Avatar
Thanks Dood!
Old Apr 22, 2006 | 10:26 PM
Tomh's Avatar
Senior Member
yep no problem.
Old May 3, 2006 | 01:32 AM
Talon's Avatar
spose this means I should go look for the sticker laugh..
Old May 13, 2006 | 01:03 PM
annie's Avatar
Is there a way to check your car to see if it's been done?
Old May 13, 2006 | 01:23 PM
Squid's Avatar
Call your dealer and ask. Mine was done before they took delivery.
Old May 13, 2006 | 02:16 PM
aziatiklover's Avatar
Master FitFreaker
I hope will be fix when I get it
urbie4
Apr 4, 2015 02:12 PM
Illusive
May 7, 2009 03:56 AM
Mainer82
Nov 27, 2008 04:38 PM
badself
Sep 22, 2008 12:36 PM
sterVin
Sep 14, 2007 06:50 PM
