jerking stop
Old May 30, 2009 | 04:46 AM
HG_OK's Avatar
jerking stop
i have a little situation when I stop at a red light or a stop sign. I have a '09 SSM Sport AT and for some strange reason my car seems too shake or jerk a little bit when I'm at a stop. I keep thinking that there's something wrong with my brakes, but that's not the case. Does anyone have that same problem? If so, please tell me what it may be and what I can do about the jerking stop.
Old May 30, 2009 | 07:57 AM
mahout's Avatar
Very strange. You might check the engine mounts and make sure they are tight to spec. And even a potential bad plug that cuses the firing to be uneven.
Old May 30, 2009 | 10:35 AM
SheepNutz's Avatar
Maybe it's downshifting into 1st, which might cause a slight jerk.
Old May 30, 2009 | 10:41 AM
trancedsailor's Avatar
my car feels like it's going to stall sometimes in Neutral at a stop. It'll dip from just under 1000rpm to about 500 for a split second. Very scary. I only have 11,000 miles!!!
Old May 30, 2009 | 10:57 PM
halfmoonclip's Avatar
Sounds like the downshift that SN mentioned. Does it do it all the time? Does it happen more when you're on a downgrade?
Moon
Old May 31, 2009 | 01:12 PM
Virtual's Avatar
Diagnose the problem. Shift into neutral before slowing to a stop. Does it "jerk" then?
Old May 31, 2009 | 09:01 PM
Speedmojo's Avatar
I get the same thing in mine as well. It's the tranny shifting into 1st early. I combat this jerk by just easing off the brakes a little earlier and if you do it right you won't even feel it.
Old Jun 1, 2009 | 01:06 AM
The useful but sometimes unwanted downshifts can be a problem on slippery roads.
Moon
Old Jun 1, 2009 | 12:02 PM
luv4jdm's Avatar
Just like speedmojo said try to ease off the brakes just when your about to stop and you won't feel it. I had this in my lexus and my tc but its normal.
Old Jun 1, 2009 | 12:47 PM
if you're going to stop for more than a few seconds, just shift your AT into neutral while approaching your stop (not while coasting).
Old Jun 2, 2009 | 02:10 PM
HG_OK's Avatar
Moon
well i hardly use SPORT that often. it doesnt happen all the time but on occasion. I would come to a complete stop and it will start to jerk.
Old Apr 22, 2010 | 03:36 AM
FitDEEZ's Avatar
im starting to have this problem aswell the car will be at a stop and it will start jerking
Old Apr 22, 2010 | 04:05 AM
Texas Coyote's Avatar
It is getting warmer, are you using the A/C when this happens? All of the other post were in May and June last year leading me to wonder if it is due to the A/C cycling on and off..... I have had this happen in other cars with small engines and automatic transmission.
Old Apr 22, 2010 | 04:57 AM
Shockwave199's Avatar
For me it happens when the AC cycles. Gotta have your foot on the brake a bit harder during those times.
Dan
Old Apr 22, 2010 | 05:34 AM
FitDEEZ's Avatar
no ac on when it happens to me.. holding the brakes a lil harder or putting it in N after stopping cures it a lil but when u put it in D it does it agen until to take off.. i think it has something to do with the motor
Old Apr 22, 2010 | 06:09 PM
FitDEEZ's Avatar
Ok so I know for sure it has something to do with the motor I have a check engine light now
Old Apr 22, 2010 | 09:18 PM
jkskrn's Avatar
Oh no... sorry to hear that... What's the code? I'm experiencing something similar. When I have my A/C on, my car rattles a bit. Also whenever the A/C comprssor goes on the whole car losses some electric power. I notice this more at night with my headlights on, and the headlights loses it's brightness time to time...
Old Apr 22, 2010 | 09:26 PM
I'd chaulk that up to normal behavior. If the car wants to lurch while at rest without the AC or defrost on, that's a different story and something more is going on.
Dan
Penquin
Jan 6, 2018 03:26 AM
nyczyang21
Mar 24, 2014 08:09 AM
Iamnotkento
Jun 11, 2011 04:10 PM
Shockwave199
Jan 12, 2010 11:06 AM
fm2n
Aug 4, 2006 11:58 PM
