does anyone put 2009 jazz(2st.) rims on 2008?
Old Jun 21, 2009 | 06:21 PM
Can_K's Avatar
Hii everone from Turkey / Istanbul
This is my first message , and i have a problem.I can't found any answer in turkey's jazz forums.And i am going to ask you..(my english is not so good,sory for them)
I have Honda Jazz 2008 Sport. In Turkey ,sport's have 175-65-14 Yokohama tires.
Yesterday ı bought 2009 Jazz's tires from a friend which is 185-55-16.
It looks so good. But i have a doubt.Does anyone put that (185-55-16) trims on 1.st Jazz? Does it rub to mudguard ? Cause a problem?
this is my car
Old Jun 21, 2009 | 06:23 PM
FITFOLLY's Avatar
Those are interesting wheels... never seen those before over here in the states.
Old Jun 21, 2009 | 06:47 PM
Can_K's Avatar
yes i know. those wheels stock on 2009 honda city in turkey
Old Jun 21, 2009 | 06:48 PM
MNfit's Avatar
im going to assume tire sizing is pretty universal. If that is the case im sure you will be fine with a 185/55/16.
Old Jun 21, 2009 | 07:00 PM
Can_K's Avatar
thanks a lot.
you said from the inside of the fender , there is no need a process?
Old Jun 21, 2009 | 07:06 PM
Super Mario's Avatar
I have 185/55/16's on my car and no problems. Those are some cool OEM wheels you have.
Old Jun 21, 2009 | 07:22 PM
Can_K's Avatar
Dear super mario , thank you for your answer.
You have relieved me of.May be more a question for you ?
-3 people sitting in the back when driving , this applies also?
Does tire rubbing on fender?
Old Jun 21, 2009 | 10:44 PM
Type 100's Avatar
Check the wheel offset - this is engraved on the inside of the wheel. GD Jazzes like yours will run best on wheels with +45 offset or higher. With that offset, you shouldn't have any rubbing problems because the wheels are "tucked in" the rear fender.
I have no idea what the offset is on the GM City rims you use.
If the offset is too low (+42 offset might have rubbing problems already, and they're definitely going to rub at +40 or lower), you'll have to look for a different set of wheels.
Old Jun 22, 2009 | 10:13 AM
Can_K's Avatar
Thanks type 100. I will take into consideration what you say.Today I went to a service,I've look at the tire.There is no friction problem.
From one end of the world, thank you very much for your interest..
Can
c4istar
Feb 8, 2016 08:33 AM
Baby-Jazz
Car Shows, Events, and Racing
Jul 8, 2013 01:25 AM
iamgine
Nov 24, 2008 05:33 PM
iamgine
Nov 24, 2008 05:07 PM
cargirl2B
May 31, 2008 06:23 PM
