Fit Idle
Old Apr 25, 2006 | 11:23 PM
bibby's Avatar
Fit Idle
When I start up the Fit, the Idle meter is at 1000rpm, is that normal to most of you? And it stays and holds at 1000rpm after the car moved. And this is under temperature about 15 degrees... Anyone here know about it?
Old Apr 26, 2006 | 12:13 AM
corey415's Avatar
15 degrees is pretty damn cold. Do you park your car outside at night?
Old Apr 26, 2006 | 12:44 AM
bibby's Avatar
Garage inside...that's why it seems odd to me. But the thing is, at 1000rpm, it doesn't go down to 750rpm even after driven
Old Apr 26, 2006 | 11:58 PM
dougiepants's Avatar
Avid FitFreak Poster
Mine is right around 700-800 RPM
Old Apr 27, 2006 | 12:20 AM
DRum's Avatar
Senior Member
Does it go down after you drive it for a few minutes? Is it an AT or an MT. An AT will usually rev higher in park than an MT will in neutral.
Old Apr 27, 2006 | 12:15 PM
Yeah mine will be at 1000 RPM when I first start it and driving it at running temp. But after driving it for awhile it wil kick down to around 700-800 RPM
Old Apr 27, 2006 | 01:02 PM
kentris's Avatar
Mine idles at just above 1000rpm when I have a cold start, drops down to around 6-800 after a while.
Old Apr 27, 2006 | 02:16 PM
fshwcrs's Avatar
same here. usually i let it warm up for a minute or 2 before driving.
Old Apr 27, 2006 | 03:20 PM
kentris's Avatar
I do that only on an extremely cold day.
But if it's just nippy out, I just drive it but make sure I don't go above 2k revs.
Old Apr 27, 2006 | 05:23 PM
Daņiel's Avatar
15C not F. 15c = 59f. Not cold at all.
Mine will run at 1000 rpm on a cold start. Then calms to about 800. Back when I got the Fit temps were around -1c (31f) in the morn, it would idle at 1500rpm for 2 minutes, then 800.
ryu
May 16, 2011 11:38 AM
phogroian
Nov 3, 2010 10:01 PM
spartan-lee
Dec 28, 2008 12:59 AM
pastafarian
Feb 22, 2008 10:23 AM
hqly
Sep 4, 2006 03:20 AM
