Has anyone done a comparison between Fit sport AT vs. Fit sport MT??
Old Apr 27, 2006 | 06:53 PM
2001CivicEXSedan's Avatar
Question Has anyone done a comparison between Fit sport AT vs. Fit sport MT??
Hello, everyone!
I'm new to this forum and this is my first post!
Anyways, I was reading an article from TOV (Temple of VTEC) about Fit and they said Fit sport AT might be faster (or peppier) than Fit sport MT due to difference in their gear ratios.
They did not do the direct comparison since they did not test drive MT and AT at the same time.
So I was wondering any of you guys have done such comparison.
Old Apr 27, 2006 | 10:00 PM
watchful one's Avatar
I tested both back to back, twice, and purchased the auto. I am a manual driver and ordered my previous element with one. The Auto feels more peppy to me too. The manual felt weird with regards to the pedal and shifter location, but was okay. The redline is 6500 rpm so this is no high reving IVtec engine and thus not nearly as fun to shift gears in as my old element.
Also, at 70 mph the auto was spinning around 2600 rpms and the manual was around 3400 rpm's. The auto also has a full manual mode that is really cool. It shifts really fast. It's also the only vehicle in this class with a 5 speed automatic (and with F1 style paddle shifters) making it a class above the rest. Just my two cents.
Old Apr 27, 2006 | 10:25 PM
DRum's Avatar
Senior Member
Given that the manual weighs less, and has 5 gear ratios in the same space as the auto has 4, and does not have a torque converter to slow it down, I would be extremely surprised if the auto was faster.
The short gearing that people are complaining about for cruising on the highway will most likely give the manual an advantage in accelerating.
The auto may "feel" fast for some reason, but I doubt the numbers bear this out.
As an example in the Honda line, the Civic MT is 1.5 seconds faster than the AT to 60 mph.
Old Apr 27, 2006 | 11:11 PM
Well... I know that manual cars are always faster than the automatic cars due to all that loss suffered in torque converter... However, that doesn't seem to apply to Fit...
Person who tested Fit on TOV said the manual LACKED some acceleration due to poor gearing compared to automatic.
I really want to get manual Fit, however, if automatic is indeed better... Then I might take AT.
And Fit AT has 5 gears just like MT.
And thanks for your opinion watchful one!!
Old Apr 27, 2006 | 11:45 PM
DRum's Avatar
Senior Member
Yes, but the ratio range of the first 4 gears of the auto match the 5 in the manual - hence less time in the sweet spot.
Old Apr 27, 2006 | 11:54 PM
Hmm... after reading the article on TOV once again... I think the auto could be tad bit faster than manual...
They just aren't a good match to the engine's output characteristics and though I didn't do any timed 0-60 runs on the car, the 5MTs ratios seemed to hurt the car's chances in that sprint, particularly if you're trying to sprint away from a light while climbing a grade. 1st gear is barely good for 30mph. Then when you upshift into 2nd, the revs fall off to around 3600rpms, and there you encounter a pronounced lull until the motor sparks back up at around 5000 rpms. You again run out of revs at 55mph and are forced to shift into 3rd.
This quote is directly from TOV article on Fit.
Until someone posts 0-60 and quarter time for both AT and MT, it won't be certain...
But IMO, I think they would pull very similar time.
Old Apr 28, 2006 | 09:40 AM
I need to read that article. It sounds similar to what I experienced. I wanted to love the manual tranny, but it didn't feel right, while the auto tranny, though weird to shift clutchless at first, felt great and much better suited for this engine. I also test drove it in on a very hilly stretch of highway and the auto held it's own.
Old Apr 28, 2006 | 10:39 AM
verily's Avatar
There's a comparison thread stickied right at the top of this forum.
Old Apr 28, 2006 | 10:48 AM
Karvin Karl's Avatar
If your going to be adding any HP the MT is better. Also, there's not to many purpose built race cars using AT's. Unless you call the SMG's Automatics or torque converter transaxle (Chaparral Cars Jim Hall RIP) Automatics.
That said, my Fit MT really would be better suited with a 6-speed.
Even my wife selected the MT over the AT! I'm keeping her, and my wife too
Old Apr 28, 2006 | 11:14 AM
Jonniedee's Avatar
Tell B & M shifters they must not be listening...
www.bmracing.com
Old Apr 28, 2006 | 08:43 PM
b17gsr's Avatar
I'll be VERY surprised if the NA auto will be faster than the manual.
Old Apr 29, 2006 | 04:04 AM
[quote=Jonniedee]Tell B & M shifters they must not be listening...
www.bmracing.com[/quote]
Thanks, Cool site but send me some motorsport cars running up front with AT's.
In all fairness I should have specified road course cars, open or closed wheel configured and not drag or off-road racing. Heel & toe skills are useless there. Plus AT's weight disadvantage.
I just don't recall anytime in the past seeing any open or closed wheel cars out there, at the tracks, set up so and running out front. But anyone, please enlighten me. I don't want my ignorance mistaken for arrogance.
Granted, F1 drivers now rely on the push button SMG's so their heel & toe skills may wane, but the drivers’ evolution from go-karts to F1/cart/indycar will surely see him only in MT cars. That said, I'm an old fart compared to most posted on the recent poll so consider my point of reference for AT's
brianr34
Mar 3, 2009 11:05 PM
itfitswell
Jan 29, 2009 11:15 AM
martymcfly
May 1, 2007 11:27 PM
creepin
Jun 26, 2006 01:42 AM
siguy
Mar 31, 2006 01:16 PM
