Problems with Reverse?
Old May 1, 2006 | 01:57 AM
mattd00b's Avatar
Anyone have trouble getting the 5 speed into reverse? Mine is sticking half way into reverse and I accidentally ground the gear thinking it was all the way in (making me cringe).
Any suggestions?
Old May 1, 2006 | 02:45 AM
JDMGD3's Avatar
Ya it seems like reverse on the MT is a bit tricky. It wont go in smoothly all the time but reverse on alot of MT's ive driven has always been this way so it doesnt bother me much.
Old May 1, 2006 | 03:20 AM
Occidio's Avatar
Yeah just release the clutch lightly and without the car in gear. Or you can allow the car to just move forward a bit with the clutch out but the stick in neutral. Happend alot on my old 240sx.
Old May 1, 2006 | 06:49 AM
sillypuddy's Avatar
Someone that Posts too much
all honda gear boxes have this problem
the trick is to put the car into 4th gear first, this will line up the synchros better.. then go from 4th gear to reverse.
i have driven hondas for over 16 years and not once have i grind the gears after doing this
-joe
Old May 1, 2006 | 07:10 AM
kentris's Avatar
Yeah this happens.
I usually just tap my accelerator and rev the car a bit and it'll get it into gear
Old May 1, 2006 | 10:18 AM
verily's Avatar
It sometimes happens on my first try to get into reverse. I just put it back to 1st and then try for Reverse again. Usually works on the second try.
I've had this problem with all MTs. I would guess it has something to do with how they set it up so that you can't throw the car into Reverse while you're going forward by accident.
Old May 1, 2006 | 11:16 AM
dartvader's Avatar
on my '90 corolla i usually have to shift into neutral, let the clutch out and then depress it again to get into reverse. still takes less time than waiting for auto to engage but on the '79 corolla i used to drive this was never an issue (it was a 5spd but had rwd)
Old May 1, 2006 | 02:42 PM
Dañiel's Avatar
Mine is a bit touchy too.
Old May 2, 2006 | 01:48 AM
Fit Is Go's Avatar
I would say this is partially true. My 1997 ITR never had this issue.
However my AE86 Corolla does and so did my FD3S RX-7 and just as mentioned; shifting to 4th with the clutch in and then going to reverse
helps.
Old May 2, 2006 | 02:05 AM
Paulo107's Avatar
i have no probs with mine...i guess either that i dont pay that much attention, but i dont grind it into reverse at all
Gordio's Avatar
This never happened to me in the fit, but it has on my dad's truck
i do remember in the manual, to reverse, either stay in neutral for a few seconds, or go to 1 and then R. I have learned to do the latter method for any car, which may be why i haven't encountered the grinding problem.
Old May 2, 2006 | 06:49 AM
sillypuddy's Avatar
helps.
I stand corrected. I have driven mostly non itr tegs, civics and accords.. so I can't say if it does for ITRs
-joe
Old May 2, 2006 | 01:43 PM
dougiepants's Avatar
Avid FitFreak Poster
I have had no trouble of any sort on mine and I have over 600 miles on it already...
Old May 2, 2006 | 08:14 PM
pokems23's Avatar
June 2007 3rd Place Fit of the Month Winner
I accidentally did that. Although, I did not fully stop when going forward.
Old May 2, 2006 | 11:43 PM
sillypuddy's Avatar
i think it depends on what gear you were in, etc.. before going into reverse..
-joe
Old May 3, 2006 | 06:08 PM
If it doesn't go in just do the normal honda trick... Put in 2nd then 4th, then try reverse... Work everytime for me...
Old May 3, 2006 | 07:21 PM
sillypuddy's Avatar
dougiepants.. just do 4th.. you should be fine..
-joe
Old May 3, 2006 | 11:15 PM
DewaltDakota's Avatar
I always did fifth, then reverse, since they're directly across from each other.
Old May 4, 2006 | 09:55 AM
DRum's Avatar
Senior Member
Funny, I never thought about it before, but I do shift into another gear and then back to reverse whenever it sticks.
Old May 4, 2006 | 10:01 AM
Virtual's Avatar
I don't think that works. My civic has a lockout that won't let you go directly from 5th to reverse.
