Upgrading 14" base wheels-- offset, and strength
Old May 1, 2006 | 01:47 PM
Bill L's Avatar
I'll be getting a base Fit & like look of the 14 x 6 Kosei K-1 TS wheels:
http://www.tirerack.com/servlet/Call...pecial=Pricing
(And at $119 each, they're not too expensive for a cheapskate like me.)
They should take the orginal tires, and there seem to be many more high-mileage tires in the 175/65/R14 than for the 195/55/R15 of the larger-wheeled Fit, but I don't know if the Kosei's +38 offset is incompatible with the +45 (or is it +55?) design of the car.
My other question concerns the weight and strength: steelies are heavier but strong, so the switch will help with unsprung weight, but will the K-1 TS be strong enough to not get bent by potholes, etc? They are billed as "racing" and only weigh about 9.3 lbs each, compared to my Miata's 14 x 6 at 12.5 lbs.
Need I be worried about either problem?
Old May 1, 2006 | 02:18 PM
wyy183's Avatar
Stock wheels are +55 offset.
Old May 1, 2006 | 02:30 PM
Dañiel's Avatar
Your link no workies.
Old May 1, 2006 | 08:46 PM
Bill L's Avatar
I seem to only be able to link to the tirerack homepage: http://www.tirerack.com/index.jsp
After that you'll need to put in all the '07 Fit info. Sorry
Regardless of the photo/info link, can anyone help me with my two questions in the original post?
Old May 1, 2006 | 09:02 PM
JDMGD3's Avatar
I would hope at under 10lbs that they are Forged wheels not Cast because a Cast wheel being that light will be prone to damage very easily if you were to hit a big pothole, it can bend pretty easily especially if you are using 50 series tires or lower.
Old May 1, 2006 | 09:23 PM
Bill L's Avatar
They are cast, but the recommended tires are the 65's of the orginal base setup. Thanks for the advice; looks like I've got some more figuring to do.
Old May 1, 2006 | 09:34 PM
JDMGD3's Avatar
I looked into these wheels in the size you wanted and they are Cast and they weigh 9.8 lbs not 9.3 but in this case its a good thing that it weighs a bit to help the wheels strength a little. 65 series is a pretty tall tire, I would at least go with a 60 series and if you lower it with some progressive springs, it should look pretty nice.
Old May 2, 2006 | 01:26 AM
cheffyjay's Avatar
I've got my eye on the K1 TS wheel also. Grassroots Motorsports magazine has described these wheels as a strong, durable, light,and a bargain.
http://grassrootsmotorsports.com/new...a-se-r/page/3/
(just photos, they had more to say in print)
http://www.koseijp.co.jp/engfl/n_p5_k1.htm
how about that crazy orange!
Tire Rack doesn't seem to be listing these as an option for the Fit sport when I search.
Old May 2, 2006 | 05:21 PM
Bill L's Avatar
Thanks for all the help folks-- so maybe the K1 TS wheels are strong enough. But what about the offset-- the originals are +55, but the 14" Kosei's are +38, so is that within the range, or do I add spacers, or what?
Jhoutz
Jul 26, 2018 10:12 AM
CityHunter
Dec 10, 2012 10:07 PM
tlm911
Dec 3, 2007 11:04 AM
Bounty Hunter
Sep 18, 2007 12:33 AM
j5ive
Car Shows, Events, and Racing
Apr 13, 2007 08:10 PM
