Road Noise
Old Sep 4, 2009 | 12:25 PM
jgaepi's Avatar
Road Noise
Does anyone not hear their A/T engine reving up when accelerating more than they should. Maybe I have had the luck of Accords before and the inside cabin is quiet and smooth but I really can hear the reving up clearly inside the cabin of my Fit. Before I start to think that somehow my dash isn't screwed down tight enough, how prevalent is your road noise. I keep my stereo on at least at a 12 level just so I don't hear my acceleration.
Old Sep 4, 2009 | 01:08 PM
Revelie's Avatar
i can hear it nicely when i hit about 4k. I actually like the engine noise. You get to hear the engine pumping out all 117 horsies. I mean, when you think of it, half the engine is under the dash. Why wouldnt you hear it?
Old Sep 4, 2009 | 01:16 PM
spin out's Avatar
there isnt much between you and the engine... or anything else.
little pebbles being kicked up by the tires sound 10 X louder than my old car.
raindrops hitting the fit's side panels sound like ice pellets/sleet.
Old Sep 4, 2009 | 01:19 PM
jcschlic's Avatar
I too went from an Accord ('07 V6 EX-L) to the '09 Fit Sport and the road noise (or engine noise) is very noticeable.
My logic on this is simple: it's not the $28K car that the Accord was. My Fit was like $17.4K.
You could probably consider using some sort of sound dampening material in order to suppress some of the noise. You could do the following:
1. Use several layers of Dynamat (or similar) materials as a hood liner.
2. Access the firewall to the car and apply further amounts of sound dampening material.
The above may work but I have not read any posts specifically in support. The added weight of sound deadener materials (although minimal) may effect MPG efficiency. Just a thought.
If you end up doing such a thing as I described, please respond to the thread so you can comment on the effectiveness as I'm sure myself and others would be interested to hear.
Old Sep 4, 2009 | 01:29 PM
jgaepi's Avatar
No sound dampening. I just want to make sure I wasn't crazy. Thanks.
Old Sep 4, 2009 | 02:44 PM
Committobefit08's Avatar
Its Normal
Its an econo car (which means very little insulation to keep weight down)and the engine is a lot closer to the cabin (thus the short hood). The back part of the engine is practically right under the dash. Just turn the radio up a little more.
Old Sep 4, 2009 | 05:25 PM
pharmpk's Avatar
Yes, it does, doesn't it. It took me quite awhile to realize it was just rain...
Old Sep 4, 2009 | 05:30 PM
mike2100's Avatar
just curious, are you drifting when this happens?
Old Sep 4, 2009 | 05:32 PM
pharmpk's Avatar
;-) no just straight ahead, its quite a sharp tap though, rather like hail. Maybe more side wind in OK
Old Sep 5, 2009 | 12:01 AM
mtunofun's Avatar
why bother with sound deadening when all you need is an iPod, CD, or PC card...NPR for the more mature folks lol.
Old Sep 5, 2009 | 01:13 AM
vwli's Avatar
You don't know what you are missing. With sound deadening, you get better sound from speakers, less road noise, less rattling. see https://www.fitfreak.net/forums/2nd-...-step-1-a.html
sunnyday
Aug 5, 2017 01:51 AM
trashercan
Dec 12, 2014 02:48 PM
Ryan2020
Jan 29, 2013 11:03 AM
geepondy2
Nov 26, 2012 05:54 PM
DesignGuy
Jul 20, 2005 01:35 PM
