Anyone pull out their USA FIT stereo?
Old May 4, 2006 | 07:59 PM
FitCustomer's Avatar
Anyone pull out their USA FIT stereo? I would like to some pictures
or perhaps a manual picture of the back of the head unit/stereo.
Since the USA version of the BASE Fit does not come with an AUX jack,
I read that perhaps one of the computer CD-ROM to motherboard audio cables
would work as input to the back of the head unit. Of course
the other end could be a 1/8" input jack for my player.
I would rather have the AUX jack plug in the glove box than down on the
console anyways.
Old May 4, 2006 | 08:54 PM
b17gsr's Avatar
If you look at the optional aux jack for the 06 Civic, the jack plugs into the radio sub harness, and communicates on the the data bus. Knowing how Honda makes most things standard, the same adapter will likely work in the base Fit. Or contact your local dealer and get them to order it (cable for the Sport).
http://www.collegehillshonda.com/ins...an/auxjack.pdf
Old May 9, 2006 | 12:05 AM
b17gsr's Avatar
Ok, according to the online manual on hondapartsdeals.com here is the part needed to add the Aux jack on a base Fit.
39112-SAA-J02ZA JACK ASSY., AUX IN
I can't find the damn cable. Someone with a US base modle should check to see if there's a loose plug under the console near the cigarette lighter, I wouldn't be surprised if it was there.
Old May 16, 2006 | 09:42 AM
Fillmatic's Avatar
I'll find out right now
Old May 16, 2006 | 10:12 AM
Fillmatic's Avatar
Negatory on that one.
Old May 17, 2006 | 01:21 AM
b17gsr: I thought all the Canadian FITs (DX/LX/EX) come with
the AUX port.
Fillmatic: I guess you have a USA FIT (base model) and didn't find the
loose plug as shown
Fillmatic: Are you going to add a AUX port? (Guess there's a couple of extra
pins available on the back of the head unit.)????
Old May 17, 2006 | 02:36 AM
Fillmatic's Avatar
loose plug as shown
No, i'm pulling the factory head unit out and replacing the bezel with the Mexican market bezel and inserting a Nav unit in its place.
Old May 17, 2006 | 09:33 AM
DRum's Avatar
Senior Member
Take pics if you get a chance.
Old May 19, 2006 | 05:01 PM
hatchgeek's Avatar
Fillmatic,
From your photos it looks like there might be a six-pin vehicle connector where the aux. jack harness would connect to...Can you just double check for us desperate base owners who want to use the Civic Aux part?
If it's really not there, my guess is down the line at some point Honda will eventually offer it for the Fit.
Old May 25, 2006 | 09:36 AM
citizenkeith's Avatar
loose plug as shown
Link isn't working...
Old May 25, 2006 | 11:09 AM
MizMamie's Avatar
See if this link works:
I'm also very curious to know if it's possible to install an AUX jack in a base Fit. Being that I'm completely clueless when it comes to stuff like this, if someone figures it out would you please post detailed instructions? Thanks!
Old May 25, 2006 | 11:13 AM
sillypuddy's Avatar
Someone that Posts too much
hook us up on the mexican bazel :-P
-joe
Old May 25, 2006 | 01:52 PM
timster's Avatar
The price is going to be around $170 for the Mexican Panel peices, this includes taxes and s/h.
If you are still interested send me a PM and I can tell you how to get a more accurate quote and I will share with you the method I used to get the parts into the US.
-joe
Old May 25, 2006 | 02:00 PM
aziatiklover's Avatar
Master FitFreaker
wow nice thanks for the infos and pic
Old May 30, 2006 | 05:42 PM
smeister's Avatar
Check this out. Auxiliary hookup for factory headunit in the Fit. I am going to do something similar in my post below.
http://ausjazz.org/forum/viewtopic.php?t=56
https://www.fitfreak.net/forums/fit-interior-modifications/5665-coming-soon-diy-auxiliary-base-fit.html
Old Jun 7, 2006 | 08:39 AM
smeister's Avatar
Pulling the headunit sucks! lol
Make sure you use the install manual for the ipod musiclink.
Old Jun 10, 2006 | 09:50 PM
smeister's Avatar
fyi
https://www.fitfreak.net/forums/showthread.php?t=5665
FYI the aussie's aux hookup did not work for the NA Base Fit.
somdamon
Aug 7, 2011 03:34 PM
runbikerun
Jan 4, 2009 07:23 PM
nebbu
May 5, 2007 11:27 AM
李克勤
May 3, 2006 08:59 PM
shipwrek
Mar 31, 2006 12:17 PM
