Remote engine starter - diy
Old Sep 26, 2009 | 01:36 PM
FITMugen's Avatar
Lightbulb Remote engine starter - diy
Did anyone install Honda FIT accessory “Remote Engine Starter” before? I looked at the instruction that came with it. It needs HDS (Honda Diagnostic System) to program it. Will a Honda dealer be only my option to program it?
Old Sep 26, 2009 | 02:39 PM
CRXsi#32's Avatar
Unfortunately yes the dealer is likely the only one who can program it properly. It is fairly plug and play so you could always install it and then take it to the dealer to get it programmed. I have never installed one and then tried starting it without programming it first so I can't say 100% it will start normally but I suspect it will.
Once it is installed the VIN number needs to be run to obtain the PCM code (for programming the immobilizer to the PCM) and then the HDS needs to be used to initialize the remote start unit to the immobilizer and PCM.
Old Sep 26, 2009 | 06:30 PM
FITMugen's Avatar
Will Snap-On ODB II diagnostic tool do the trick as HDS? I hate to spend $95 per hour labor charge for 15 minutes job at the dealer.
Old Sep 27, 2009 | 03:48 AM
CRXsi#32's Avatar
I honestly don't know if it will do it as I haven't used it on a Honda.
NoVAFit
Apr 2, 2016 02:53 AM
kaikou
Nov 21, 2014 11:51 PM
guitrldy
Aug 17, 2011 02:45 PM
triton.
Mar 21, 2009 10:23 PM
PurrfectFit
Canada Fit Forums & Clubs
Dec 31, 2006 01:33 PM
