Manual Fit Question
Old May 9, 2006 | 07:24 PM
Keep Fit's Avatar
Manual Fit Question
I am going uphill and stop, when I start moving, the car always roll back.
Is there any technique to start without rolling back?
Old May 9, 2006 | 07:34 PM
Berto's Avatar
is this your first manual? that is normal you will get good at it eventually.
If I ever need help taking off in a very steep slope I pull up on the hand brake so that i can take my foot off the brake and onto the clutch and get it to the point at where it grips.
try this in a flat parking lot and you will see you can feel the car shift when the clutch engages, then u simply let off the hand brake and go on your merry way. i hope this helps.
Old May 9, 2006 | 07:49 PM
kentris's Avatar
This is why you should all start off with manual driving before going off to autos :P.
But yeah it's normal, because you haven't got the "biting point" so the cogs/gears aren't engage which it needs to in order to move the wheels.
Follow Berto's tips above, that helps on a hill, if you feel the car is going to stall, apply a little bit more gas.
Old May 9, 2006 | 09:16 PM
frossie's Avatar
You might find this useful:
http://www.driving-test-success.com/...rt_uphill.html
Use a handbrake start on all hills until you are confident of your clutch control, then you can do it on mild slopes just with the break.
Old May 9, 2006 | 09:38 PM
GoFit's Avatar
Someone that Posts too much
I agree with the hand brake method.
Old May 9, 2006 | 10:35 PM
SheepNutz's Avatar
I do the handbrake method if I know I'm going to be stopped for a while. If I stop at a light on a steep hill, and I know it's about to turn green, I'll just ride on the gas and clutch right at the bite point until its time to take off.
Old May 9, 2006 | 10:41 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
its even scarier when its rainning.. i dunno about snow since it doesnt snow in Austin..
Old May 9, 2006 | 11:01 PM
kingdlx's Avatar
Use the e brake to hold until you get the clutch engaged,
Old May 10, 2006 | 01:56 AM
Paulo107's Avatar
would to give you advice , but i live on flat land
Old May 10, 2006 | 02:00 AM
Okietom's Avatar
Subaru hill-holder
Subaru has the neatest thing for this situation. My old 82 Subaru had a device called a hill holder. There was a cable from the clutch lever beside the clutch cable. My clutch was slipping and I went to adjust it and found it. It went to the brake system where it had a ball in it that rolled back over a hole in the brake valves. If your car was at an uphill angle this ball would hold brake pressure on two wheels, one in front and one in back on the opposite side, as long as you held the clutch pedal down. You could put your foot on the accelerator and give it some gas while holding the clutch in without the car rolling back. I have been baffled as to why other or all manual shift vehicles don't have this simple device. Anyone living in San Francisco should drive a Subaru just for that. It would have been great for hillclimbing in a 4wd Subaru.
DaveD912
Mar 6, 2019 07:48 PM
Ogrelode
Dec 2, 2018 01:50 PM
indyc350
May 25, 2015 03:56 PM
mike2434
Jul 11, 2010 04:49 PM
Cold493
May 8, 2007 03:15 AM
