J swapping?
Old Nov 23, 2009 | 03:14 PM
kylerwho's Avatar
spoon fed
J swapping?
this month's honda tuning was really interesting with an ek that had a j32 swap in it.
anyone want to try mashing it in a fit? doesnt look that huge except that it stands taller.
Old Nov 23, 2009 | 03:44 PM
redrumm's Avatar
i thought there were already a few that had that motor in a ek chassis?
seems like it would stick out of the hood more than the civic/integra chassis or close to the plastic trim under the window.
Old Nov 23, 2009 | 03:49 PM
kylerwho's Avatar
spoon fed
the honda fit has more hood clearance then eg/ek/dc. my only concern would be the width of the engine compartment.
i wish i had some measurements so i could test that out.
Old Nov 23, 2009 | 03:50 PM
redrumm's Avatar
ha back to the drawing board
Old Nov 23, 2009 | 03:51 PM
kylerwho's Avatar
spoon fed
i have had some crazy ideas but i would love to be the first to try this swap. ha ha ha
Old Nov 23, 2009 | 03:54 PM
redrumm's Avatar
well do it. there is a guy here local trying to put one in a DA. he is custom fabing mounts and everything.
Old Nov 23, 2009 | 03:58 PM
redrumm's Avatar
idk man it sticks out a lot lol
gotta be heavy on the front
Old Nov 23, 2009 | 04:17 PM
kylerwho's Avatar
spoon fed
yeah i saw that guys thread on k20a.org
there is also a guy who did probably the first j swap into an ef civic. sticks way out of the hood. custom metal work will have to be done.
i think it weighs 200lbs more than a k series.
Old Nov 23, 2009 | 05:20 PM
dewthedew's Avatar
That's just overkill...lol I still say
f20c
Old Nov 23, 2009 | 06:23 PM
kylerwho's Avatar
spoon fed
f20c has too much negative lean toward the firewall. doesnt look like i would be able to do it.
my new plan is to get a dc2 type r from japan and drop the f20c into that and swap a k20a into the fit. if both engine bays are open at the same time i will attempt to put the f20c in but i have strong doubts.
im just bored and considering the j32a.
anyone else have any input?
Old Nov 27, 2009 | 11:27 AM
TurboManGT's Avatar
Haha throw it in the back. RWD FTW
Old Jan 8, 2010 | 12:49 PM
Padraic's Avatar
There is a local guy that has a J swapped Type-R. I think he bought the Type-R after it had been stripped, so there was no engine in it. I won't bother posting the link, because you have to be a registered member of STLHondas to see it.
He does have a hood on it too, it needed some of the under-hood webbing cut out to fit.
Old Jan 8, 2010 | 08:16 PM
redrumm's Avatar
are you sure he didnt cut the hood out too?
i took a pic of this at Import alliance
the manifold doesnt even clear the hood skeleton even if it was lifted in the rear
Old Jan 9, 2010 | 01:52 AM
Fitting's Avatar
Old Jan 9, 2010 | 09:50 AM
Padraic's Avatar
I think you might need to be registered to read this, so I will quote a couple lines.
StlHondas
From the thread: I cut the webbing, swapped manifolds and lowered everything down 1.5in. The oil pan wont scrape. There is PLENTY of clearance...
I spaced down the mounts and subframe equally to keep the engine/ axle angles the same. It sits about 1.5in lower than before. I plan on compensating the height differences through the coilovers.
He is using a 09 TL 3.7 manifold so that there is more clearance. The engine is from a CL Type-S.
I like what he did as I am not a fan of the exposed engine look. This car looks stock from the outside.
Old Jan 9, 2010 | 11:09 PM
redrumm's Avatar
dang crazy! cool swap just dont really see the point though
Old Jan 10, 2010 | 11:32 AM
TurboManGT's Avatar
Maybe to be different
Old Jan 10, 2010 | 05:37 PM
Texas Coyote's Avatar
If your going to stuff a larger engine into something why stop at a little bit larger? ... Engine swaps are almost always overkill in one way or another.
Old Jan 10, 2010 | 08:29 PM
TurboManGT's Avatar
Lol you won't budge on swapping will you Coyote
Old Jan 10, 2010 | 08:59 PM
I wouldn't want to see a perfectly good car messed up with a swap and there aren't many cars around that aren't a mess of problems after an engine swap..... It is very difficult to do one right without spending a lot more than intended...... It is just a matter of opinion from an old guy that has done a few swaps and ridden in and driven a few more...... Pick up trucks are a breeze though.
