Obdii/can scanner problem
Old Dec 5, 2009 | 04:33 PM
nahama's Avatar
I got Eng check light on.
I just bought AUTEL Maxiscan MS409 OBD-II/CAN compliant.
Somehow, it does not make link. It shows status bar that stays low end and doesn't go up no matter how long wait.
When turned off the key, the bar goes up and it shows "ISO-9141-2, KWP2000, and "linkage error" Try again"
Strange thing is that when i borrowed other brand, it works fine, but the other well known brand. I belive both are CAN compliant too.
Is there way to solve this problem?
When i borrowed other scanner, code cameP0301 misfire on cyl 1.
I got 108K miles on it.
I changed plugs 8K miles ago, now I changed all Ign coils.
It still uneven.
What next? Fuel injection?
Old Dec 24, 2009 | 09:42 PM
validcustomer's Avatar
Does this help?
Amazon.com: S. Mundle "Sonny"'s review of Autel MaxiScan MS300 CAN OBD-II Scan Tool
I don't have one but did read this comment by someone getting a link error with a Maxiscan and suggesting a work-around.
Old Apr 11, 2011 | 07:55 PM
lolly's Avatar
Hi ,my GS400 works fine with honda crv 2003 b
Originally Posted by nahama
I.But not with HONDA JAZZ 2009.Could you let me know which scanner you use for this new Jazz?
When turned off the key, the bar goes up and it shows "ISO-9141-2, KWP2000, and "linkage error" Try again"on
It still uneven.
Nussjohnathan@gmail.com
Nov 23, 2020 09:03 PM
Silvermelon19
May 25, 2016 05:52 PM
kitenok
Dec 10, 2015 07:28 PM
$p!@t1027
Apr 13, 2014 04:33 PM
CTCT
Nov 26, 2012 10:00 PM
