has anyone adjust their valves ?
Old Dec 10, 2009 | 04:11 PM
storm's Avatar
i have a 2007 sport 110,000 miles. feel like the valves might need to be adjusted. i have not worked on import yet. any help would be great....thanks.
Old Dec 10, 2009 | 09:25 PM
gimme's Avatar
Master FitFreaker
damn, im at 60k and ready to. they feel and sound pretty sloppy. the one thing holding me back is the torque spec, gaping and the sequence.
Old Dec 10, 2009 | 09:49 PM
willy65000's Avatar
There's a thread in this forum called valve clearance I believe. It covers the whole procedure with picrutes and everything. I for sure wouldn't do it with out a torque wrench. I picked mine up at Home depot for a cheap price. Oh, and you'll need a set of feeler gauges. Get a fairly large set so you're covered or just make sure the correct ones are in the set. The valve them selves are easy to adjust. The pain in the ass part is getting to them.
Old Dec 10, 2009 | 09:52 PM
Perrenoud Fit's Avatar
yea check out p.2 on Poor Gas Milage.Suggestion thread you will find torq specs, gaps and sequences, hope this helps
Go To Valve Clearance great illustrations!!
Old Dec 10, 2009 | 10:42 PM
gimme's Avatar
Master FitFreaker
i have everything. i have done my valve adjusts on every honda i have ever owned, just feel weird about the fit.
Old Dec 12, 2009 | 03:21 PM
storm's Avatar
thanks everyone. as soon the weather gets alittle warmer.i will dig into it.
Old Dec 12, 2009 | 04:43 PM
dewthedew's Avatar
search there is a better thread about this topic.. my fit is barely at 20k and I want to do it lol
Old Dec 25, 2009 | 09:07 PM
Black01's Avatar
I've been looking to do this too. I'm at 64k!
Old Dec 25, 2009 | 09:27 PM
Black01's Avatar
Hi, can you post the link for this thread? I did search fot but I cannot find the thread. Thanks.
Old Dec 26, 2009 | 09:30 PM
seeremlive's Avatar
I was looking for the same thing yesterday and found this thread. This has a step by step with pics.
https://www.fitfreak.net/forums/fit-...clearance.html
Old Dec 27, 2009 | 12:07 PM
Black01's Avatar
Thank you for posting that link. That looks like a lot of work. I may do that procedure next weekend.
Old Dec 27, 2009 | 01:09 PM
seeremlive's Avatar
Make sure to pick up a new gasket and bolt seal kit for the Cylinder Head Cover (valve cover).
Full kit Part # 12030-PWC-000 (Contains both of the below parts)
Gasket Part # 12341-PWC-000
Bolt Seal Part # 90442-P0A-000
Bernardi Link
Find Honda Parts and Honda Accessories by Car Model - Bernardi Honda Parts and Accessories
THESE PARTS ARE FOR GD (07-08) ONLY. GE PARTS ARE DIFFERENT.
Old Dec 28, 2009 | 12:45 AM
polaski's Avatar
Do you guys replace the IM o-rings?
Old Dec 29, 2009 | 06:40 PM
willy65000's Avatar
I took the manifold off at the cylinder head which has a metal gasket and I've had no problems with leakage. I also reused the valve cover gasket. This may have been covered earlier but you'll want some Hondabond for the part of the mating surface that's near the cam.
Old Dec 29, 2009 | 06:53 PM
seeremlive's Avatar
Good tip about the Hondabond. I have however also reused a head gasket but I didn't run the engine more that a few miles. (I had to replace one of the valve springs.)
I just don't like reusing gaskets. Most of the metal ones are designed to be put on and torqued down, which crushes the gasket into the proper shape. When it is reused it can distort and not seat properly.
For under $30.00 there is less of a chance of having an issue that will make it so you have to tear the whole thing down again and then buy the gaskets anyway.
Old Dec 29, 2009 | 09:41 PM
willy65000's Avatar
Yea, reusing gaskets is a little risky but that's actually what the guy at the Honda parts counter suggested. By the way what was your reason for replacing a valve spring?
Old Dec 30, 2009 | 12:05 PM
seeremlive's Avatar
That was on my old Nova. I had rebuilt the heads and accidentally put one of the old springs back on an intake valve. While adjusting the rockers I noticed that it was a different color. 2 hours later I was back in business.
Old Jan 10, 2010 | 05:59 PM
Black01's Avatar
Well I have not worked on tightening mine yet due to the weather(too cold to do it), I may end up taking it to the dealer plus I don't have the time to do it and not confident enough for my Fit is my only means of transportation. Does anyone know how much is this type of job? Thanks.
Old Jan 22, 2010 | 11:24 AM
vag0's Avatar
x2 I guess these types of engines need this done because my engine needs a valve adjustment as well, Im only on 44k but its too too cold outside to work on it.
Old Feb 28, 2010 | 07:42 PM
Black01's Avatar
I just did mine today. It took me 4.5hours, it killed my back! Great experience though. I notice that the clearance on the exhaust is pretty much close to nothing so I had to adjust that. My only question is how much drag should I be expecting to do? Because when I did it, I just made sure that the feeler guage would slide in freely but with enough drag.
