Can't open hood
Old Dec 24, 2009 | 11:06 AM
CrystalFiveMT's Avatar
Can't open hood
So I was upgrading my horn and I had to move the hood release cable out of the way, and I thought I put it back in place, but when I tried to open the hood this morning the interior hood release lever pulled all the way back without tension. I tried tugging on the cable and fiddling with the latch release under the hood, but I can't open the hood. Any tips? Thanks.
Old Dec 24, 2009 | 03:36 PM
hogwylde's Avatar
Did it become un-done at the latch?
Old Dec 24, 2009 | 04:31 PM
Well, I unhooked the cable from its slot during my working on my project, but at the end I thought I reattached it. Maybe it wasn't exactly secured.
Old Dec 24, 2009 | 08:22 PM
macbuddy's Avatar
Try disconnecting the lever from inside the car, then tug on the assembly as a whole. I did that with my 1965 MG Midget, and luckily, I was able to open the hood.
Good Luck,
-macbuddy-
PS-This will only work if you did not disconnect the cable from the release mechanism under the hood.
Old Dec 25, 2009 | 12:09 AM
Ok thanks, I'll give that a try.
Old Dec 25, 2009 | 01:57 AM
hogwylde's Avatar
And don't forget the KISS rule. What was your last step when you removed the cable?
Old Dec 25, 2009 | 06:31 AM
Black3sr's Avatar
This is going to get expensive. I can see the grille being ripped out to get at it but then you wanted a new one.
Oh why did you remove the cable? None of the DIY threads said to do this.
Good luck.
Old Dec 25, 2009 | 10:59 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
Good luck.
X2 on why did you remove it?
Old Dec 25, 2009 | 12:49 PM
Virtual's Avatar
Any progress? I'm just curious if you found a solution.
Old Dec 25, 2009 | 01:48 PM
hogwylde's Avatar
You didn't mention what year Fit you had. Does this help?
Download PDF Honda Jazz Fit Service Manual | PDFTown.com
benmaggoswd1
Mar 19, 2018 10:20 AM
mizike
Feb 14, 2018 05:51 AM
CrystalFiveMT
Oct 2, 2014 05:09 PM
Guinness
Dec 10, 2007 11:40 PM
Elle
Aug 12, 2005 11:34 PM
