short shifter help asap
Old Dec 25, 2009 | 01:47 PM
andyd's Avatar
how in the heck do you get the shifter out of the housing for the t1r shifter, i am so confused on how you would do this without 4 arms.
here is a pic of where i am at:
Old Dec 25, 2009 | 02:34 PM
rvall004's Avatar
They have a do it yourself..look it up.....u need two flat head screw drivers...it would be helpful if u could find a buddy that can help you out
Old Dec 25, 2009 | 02:53 PM
andyd's Avatar
i looked at the diy for the mugen one, could not find the t1r one. i have been prying for hours.
Old Dec 25, 2009 | 03:10 PM
k20a298ek's Avatar
if you look you will see 4 clips pry one at a time with a flat head screw driver. after you have the shifter out let the shifter sit in boiling water to exspand the bottom nylon bushing and pry it off.
Old Dec 25, 2009 | 03:13 PM
kylerwho's Avatar
spoon fed
just take your time and press in the 4 little clips that is holding shifter down. it will take alot of time but it will come out eventually.
Old Dec 25, 2009 | 04:17 PM
andyd's Avatar
okay. Its just every time i get one clip up i work on another and is slips back in. Taking a break till tomorrow, haha.
Old Dec 26, 2009 | 03:21 PM
wait4thefit's Avatar
i pushed the clips in from the side and it worked great try that. get a couple of screw drivers and wedge them in each clip and it should slide out
Old Dec 26, 2009 | 04:59 PM
andyd's Avatar
finally got that piece out. Now how do you get the side part out where the spring is? Do you take the whole thing apart?
MrKeishii
Mar 21, 2014 10:24 PM
scarygoldlion
Sep 27, 2010 02:22 PM
xaircooledx
Jan 13, 2009 01:52 AM
j6kwok
Jan 7, 2009 02:37 PM
xanatos
Aug 26, 2008 11:06 AM
