Issues.. help...
Old Jan 7, 2010 | 07:53 PM
hqly's Avatar
Issues.. help...
My cruise control and S feature doesn't work. Anyone have similar experiences and know what is the problem?
Also, where can I get a list of work performed at a 30k service? Can't seem to find that anywhere. I would like to know what is included.
Old Jan 7, 2010 | 08:01 PM
hqly's Avatar
I'm planning to schedule an appointment to bring the car in. Are there any recalls or bulletins for the fit in the past 2 years? I got the wind noise done but not the milage issue. Maybe they'll still fix that for me. I kinda ignored it since i received the letter.
Old Jan 7, 2010 | 10:47 PM
Fitcious's Avatar
honestly, if it's something as serious as the paddles and cruise and if isn't the fuse..just fork out the money and let the honda dealership check it out. you don't want an outside mechanic to check it, then give you some false/incorrect info...do something that isn't need and the problem still persists. I would do it right the first time, even if it means to fork out a litle extra. at least you can bitch at the dealer and get them to fix it if they promise you that they will.
Old Jan 12, 2010 | 11:49 AM
hqly's Avatar
Anyone know which fuse is for the cruise control and the sports feature?
The manual doesn't say but i have a feeling that they may share a fuse with something else. I just do't know what...
Old Jan 13, 2010 | 11:16 AM
hqly's Avatar
I checked all the fuse and all were fine.. i guess it's something beyond the fuse.
Old Jan 13, 2010 | 11:35 AM
BlueCell's Avatar
Check your main grounding points, sometimes those get loose. There's a big grounding point on the driver side frame when you take off your front bumper. Also another one on the passenger side.
Old Jan 13, 2010 | 12:05 PM
hqly's Avatar
How do I do that? Do the bumpers come off easily? Are the grounding points wires? Check to see if they were connected?
Old Jan 13, 2010 | 12:23 PM
BlueCell's Avatar
What year Fit? I'm not sure how to take off the 09 bumpers.
Grounding points are wires with a 10mm bolt connected to the chassis. If that bolt is lose, it will cause a shortage.
Brad
Nov 21, 2013 11:42 PM
90 DGRZ
May 31, 2011 04:10 PM
FELIXY69
Nov 21, 2008 08:04 PM
DarkStorm
Aug 14, 2008 02:23 PM
Steeldog
Aug 22, 2007 10:26 AM
