Tire, Wheel, Brake & Suspension Welcome to the FitFreak.net Tire, Wheel, Brake & Suspension Forum
Tire/Rim Sizes?
Old Jan 7, 2010 | 11:42 PM
uRabbit's Avatar
Tire/Rim Sizes?
Wondering what size tires/rims can be installed on the Fit and not cause issues? Been a while since I bought tires and never have for the Fit.
Old Dec 14, 2011 | 12:55 PM
isis07734's Avatar
Ditto,
I see all this talk about camber, offset, rubbing, etc... how big/wide a tire can one put on a stock sprung Fit in both 15" and 16" wheels? (without needing to adjust camber/offset/deal with rubbing.
Old Dec 15, 2011 | 07:26 PM
LscAndrew's Avatar
Go to Tirerack.com and check. Do you have a GD or GE?
Old Dec 16, 2011 | 09:54 AM
isis07734's Avatar
Thanks, Andrew, ill go check it out now!
GE
Old Dec 16, 2011 | 10:58 AM
LscAndrew's Avatar
I have been doing research on rims and tires recently, and I decided to purchase a set of 16"x6.5" Kosei K4R rims [$159 (each)] with 205/50-16 Yokohama AVID ENVigor (H&V) tires [$103.00 (each)]
For the rims, each of them is only 12.8lb in weight, which is much lighter than the 16" OEM rims (~19lb). Plus, they are manufactured in Japan! Another set of rims, Enkei Racing RPF1, are also recommended. They are even lighter (9.5lb), and they are pretty common on streets.
For the tires, TireRack.com recommended the size of 185/55-16, but there are so few choices of this size and none of them have good ratings, so I decide to use the size of 205/50-16.
Hope this helps.
Old Dec 23, 2011 | 09:24 PM
isis07734's Avatar
My reading is pointing me twds 195/65/15"s. Why did you choose the 6.5 vs the 7?
Old Dec 24, 2011 | 01:34 AM
LscAndrew's Avatar
The overall diameter of the original tire is 24", but that of 195/65/15 is 25.1". I don't know if this is going to rub your fender, you gotta check.
I did not pick 6.5", it just happened that the rim was 16"x6.5".
Old Dec 25, 2011 | 04:27 PM
isis07734's Avatar
Really liking your choice...
thinking hard about the 15" version with 195/60's... which would be the same diameter as my stock Base 175/65/15" ?
Old Dec 25, 2011 | 04:38 PM
isis07734's Avatar
found this...
Tire size calculator
Old Dec 25, 2011 | 04:39 PM
LscAndrew's Avatar
Yes they are around 24"
Lymer
Aug 26, 2016 04:56 AM
pltambon
Mar 13, 2013 08:36 AM
glong
Jan 20, 2013 11:35 AM
roguenode
Aug 14, 2011 09:33 AM
jurassicJAM
Jul 21, 2010 08:44 AM
