camber bolts
Old Jan 25, 2010 | 09:53 PM
flushge8's Avatar
camber bolts
does anyone know if the gd camber bolts fit on a ge if not where can i get it and how much is it thanxs
Old Jan 26, 2010 | 12:10 AM
HONDAMATIC's Avatar
for the front? im pretty sure theyll fit.. possibly revision audio or ebay
Old Jan 26, 2010 | 01:51 AM
flushge8's Avatar
alright thanx
Old Jan 26, 2010 | 05:00 AM
chinkyy's Avatar
lets see some pics of the flushge
Old Jan 26, 2010 | 03:21 PM
ToyotaFIT's Avatar
are camber bolts just used to bring the toe out (where the wheels appear to be angled outward at the bottom and inward at the top) so that you can get that flush look?
or are camber bolts used strictly for alignment? bc i got an alignment w/o them for gd.
Old Jan 26, 2010 | 05:18 PM
HONDAMATIC's Avatar
camber bolts change your camber angle, usually for alignment but can be used for evil as well!
stock honda only has toe adjustment, which is usually good enough, but when you lower, the camber gets worse (not really with mac strut cars, such as fit) so you use camber bolts to straighten them out, or you can use them to add more camber to get better looks
Old Jan 26, 2010 | 07:22 PM
ToyotaFIT's Avatar
oooooohhh so i could possibly make my rims look a lot more flush if i just some spacers and a camber kit?
or put on my wider rims? cuz when i had my 7.5" rims on i would rub till smoke came out every so often...
Old Jan 26, 2010 | 09:01 PM
HONDAMATIC's Avatar
well the back is harder to add camber, thats the thing..
Old Jan 26, 2010 | 09:32 PM
solbrothers's Avatar
yeah, you gotta remove the rear brakes to install the camber shims. thats what holding me back from installing my 25mm spacers
Old Jan 26, 2010 | 09:33 PM
flushge8's Avatar
yah ill post pics on saterday wen im done with everything
Old Jan 27, 2010 | 03:53 AM
tanukifit's Avatar
Island Brake and Alignment has em. Go see Derrick and tell em the scca guy with the Fit sent you. haha. You might as well have them put it on and align it because you have to do it anyways.
Old Jan 27, 2010 | 04:00 AM
tanukifit's Avatar
Oh and another thing negative camber tucks more but performs better / \, positive camber might be a little dangerous \ / unless you like sliding around.
Old Jan 27, 2010 | 04:03 AM
tanukifit's Avatar
Island Brake and Alignment has the shims too. One day when I got a long brake I might go check Derrick out. I want reduce the negative camber in the back so I can get some oversteer.
Old Jan 27, 2010 | 03:15 PM
ToyotaFIT's Avatar
i had them do my alignment, derrick is a good guy he even hooked me up with a realignment for my attempt at recon.
i wonder if theyll be nice enough to realign my car if i pay them to put in some camber bolts/shims... wouldnt mind some neg. camber.
Old Jan 27, 2010 | 04:01 PM
just adding to this, but if you make neg camber in the front, GET AN ALIGNMENT! the way our cars work, if you add neg camber, you also throw off the toe. i chewed through a pair of brand new 205/40/17's in 300 miles because of this. firestone lifetime alignment ftw!
Old Jan 27, 2010 | 05:02 PM
HONDAMATIC's Avatar
yup added camber bolts and tires were squealing like crazy after.. good thing it was only the next rack over
Old Jan 27, 2010 | 06:06 PM
i raped my wheel bearings because of terrible toe
Old Jan 28, 2010 | 07:05 PM
kingsize's Avatar
alignments are reaaaaaaaaaally important to reduce excessive wear on your tires. bad toe angles can be bad!
Old Feb 1, 2010 | 03:03 PM
beangrower's Avatar
lets see that flushness yo.
Old Feb 2, 2010 | 03:16 AM
flushge8's Avatar
here are the pics
