FS: 07-08 led tail lights moded
Old Feb 5, 2010 | 05:38 PM
benmunger's Avatar
07-08 led tails. All leds are working. 100% functional
i cut off the tabs on the bottom so they will line up with the USDM bumper perfect.
They are not JDM OEM
I painted the tops of them with OEM matched silver paint. I couldnt get it to be smooth and gave up. Please do not consider buying these unless you intend to sand/repaint the area that I painted. The plastic under the paint is unrecoverable unless you are some kind of paint genius/magician.
There is also an imperfection on the passenger side in the area that i indicated in blue. As you can see the imperfection is not that easy to see. I just wanted to give an accurate description.
$70 delivered to USA
$60 pick up Broward, Pembroke Pines, FL 33029
please PM me for paypal address.
Old Feb 5, 2010 | 09:43 PM
wobuffet's Avatar
so what exactly is the imperfection??
btw, have you tried paint stripper?? i heard it's just a liquid you apply on the paint and it starts bubbling and you can just rub it off afterwards?? correct me if i'm wrong..
Old Feb 5, 2010 | 09:48 PM
benmunger's Avatar
Imperfection, its frosted/cloudy a bit... I know, you can barely see it.
I didn't try stripping it... I dont want to damage it any farther.
Old Feb 6, 2010 | 04:08 AM
chrisng's Avatar
just curious.. what do these look like on the car. i'm assuming that they're ssm?
Old Feb 6, 2010 | 08:22 AM
benmunger's Avatar
They look really good but they need to be repainted, or sanded and painted over.
Yes they are SSM.
Old Mar 2, 2010 | 08:32 PM
benmunger's Avatar
bump
Old Mar 2, 2010 | 11:00 PM
sevenaprils's Avatar
Acetone should take it off and shouldn't damage the lenses.
Soak a rag in it then lay it over the painted area and let it sit for a bit.
And use good ventilation.
Mini_Odyssey
Jul 8, 2015 02:05 PM
RetroAttack
Jun 11, 2012 04:59 PM
Retrofit09
Sep 2, 2009 07:14 PM
slo_motion
Mar 3, 2009 01:52 AM
airborne200208
Apr 30, 2008 09:17 PM
