KW supercharger w/fmic??
Old Feb 7, 2010 | 11:08 PM
im the fit's Avatar
Any pros/cons??? Also what would be a ideal size intercooler to use?
Old Feb 7, 2010 | 11:13 PM
keepitpg's Avatar
i love college
you'd be blocking the rotrex oil cooler (i think) and you might as well install a bov since you're replacing all the piping
Old Feb 7, 2010 | 11:16 PM
im the fit's Avatar
I am down for a BOV...least of my worries though.
Old Feb 7, 2010 | 11:40 PM
keepitpg's Avatar
i love college
i dont think youd have any problems at all other than the blocking of direct airflow to the rotrex oil cooler, but i'm sure that can be fixed
Old Feb 7, 2010 | 11:49 PM
im the fit's Avatar
Boost loss....lag.. are really what I am concerned about.
Old Feb 8, 2010 | 03:38 AM
MNfit's Avatar
they make a tmic
Old Feb 8, 2010 | 09:42 AM
Texas Coyote's Avatar
Whether you do an inter cooler or not you can gain performance with hood louvers..... The problem is the under hood temperature.
Old Feb 8, 2010 | 10:01 AM
im the fit's Avatar
[QUOTE=Texas Coyote;810807]Whether you do an inter cooler or not you can gain performance with hood louvers..... The problem is
i dont have high underhood temps..
Old Feb 8, 2010 | 10:36 AM
Smile
..... I thought my car was relatively cool under the hood until I realized how much stronger it ran when ambient temperatures were 70 degrees or cooler.... Heat has 2 times the effect on power loss on a boosted engine than N/A.... In stop and go city driving an inter cooler isn't going to be as effective as it would be with a louvered hood and just venting the hood alone will show a power increase on a super charged Fit.
Old Feb 8, 2010 | 12:31 PM
dewthedew's Avatar
this size will do..
Old Feb 8, 2010 | 05:48 PM
im the fit's Avatar
this size will do..
It needs to be bigger than that.
Old Feb 8, 2010 | 06:33 PM
MNfit's Avatar
I think a size like this would work
Old Feb 8, 2010 | 07:27 PM
dewthedew's Avatar
thats so small lol
Old Feb 8, 2010 | 07:37 PM
JDMchris.com's Avatar
I run THIS
It actually doesnt need to be much bigger than that... Net gain for a bigger FMIC is only going to be about 2-3whp more over the KW top mount.
Old Feb 8, 2010 | 09:30 PM
Think louvers and methanol/water injection if you really need to cool it down..... An engine oil cooler, 160 degree thermostat colder plugs and wrapped header will also help.
Old Feb 9, 2010 | 06:48 AM
Koi's Avatar
Koi
Louvers/venting the hood using washers = drop of IAT around 15-30 degrees F, and much faster cool down after the heat builds up from boosting. That's my experience with my kit & venting the hood anyways.
Old Feb 27, 2010 | 10:14 AM
im the fit's Avatar
I would be happy with that....!
Old Feb 27, 2010 | 11:39 AM
If you don't have high under hood temperatures why would you go to so much trouble to mount a FMIC?
Old Feb 27, 2010 | 12:48 PM
dewthedew's Avatar
underhood temps are different than intake temps
Old Feb 27, 2010 | 01:28 PM
im the fit's Avatar
Not trouble at all!
