GE8 Camber recommendations?
Old Feb 10, 2010 | 01:20 AM
Fit2010's Avatar
Looking for recommendations on front and rear cambers kits for our GE8's. I installed Eibach prokit on 17x7 205/40-17 +45. Looking for some cambers now, Anyone have sites and pricing available. Doesn't seem like there are any out there.
Old Feb 10, 2010 | 01:36 AM
lilaznphatboy's Avatar
i was talking to JDM_DOHC_SiR, n he said that we can used the Camber bolt off of a '06+ Civic Si. you can just go to your local honda parts dealership n order it from them
Old Feb 10, 2010 | 01:46 AM
vinn's Avatar
Roughly $12-13 for all four in the front
heres the
P/N 90188-SCC-A00
and a big no no for change the rear camber
Old Feb 10, 2010 | 02:38 AM
Fit2010's Avatar
Thanks i'll do that. also you said DON'T change the rear cambers?
Old Feb 10, 2010 | 09:12 AM
Tork's Avatar
The rear is rough because the rear hub plates are welded to the torsion beam not bolted on like the GD
Old Feb 10, 2010 | 12:28 PM
beangrower's Avatar
Unless you want to bring in one of these bad boys from japan for $1313.46 shipping not included):
hey vinn, is that part no. for the SI camber bolts? for $12 bucks...i'll go that route. I was gonna buy some SPC camber bolts which was like $20-30 for a pair.
Old Feb 10, 2010 | 12:36 PM
dela's Avatar
+1 i'd rather have OEM anyway, think i'll pick these up if they are the Si bolts
i picked up some SPC bolts and the bolt head and nut dont match... the head is like 15 mm and the nut was actually like 19 mm... so off sizing... eh... dont really wanna put these on... anyone wanna buy them?
Old Feb 10, 2010 | 03:27 PM
vinn's Avatar
The bolt part number is what is listed on the sticky to convert the USDM Fit to a JDM Fit.
If you change the bolt, remember you need to get an alignment!
And I don't have to go to Japan or Asia to get that trailing arm....
Old Feb 10, 2010 | 05:01 PM
beangrower's Avatar
^but it does allow to correct camber...right?
u can get that trailing arm? how much?
Old Feb 10, 2010 | 05:05 PM
vinn's Avatar
you should be allowed to correct with the front.
the trailing arm? well i think youre better off getting it in japan than where i would get it and its roughly around the same price
Old Feb 11, 2010 | 12:40 AM
0r30kid's Avatar
so this may sound like a complete noob question, but it is something I have wondered and never really bothered to find out. What exactly does a camber kit do?
Old Feb 11, 2010 | 10:36 AM
dela's Avatar
our cars dont come with camber adjustment... so camber bolts/kit lets us do that for proper alignment...
heres some food for your mind
http://en.wikipedia.org/wiki/Camber_angle
Originally Posted by taken from mr2oc.com
More negative camber front: less under steer because of better lateral traction as tread is flatter on the ground under side load.
Usable range: up to 3.5 degrees negative
Symptoms of too much adjustment: poor braking; car is road crown sensitive; twitchy; front tires wear on inside edge
More negative camber rear: less over steer because of better lateral traction as tread is flatter on the ground under side load. More rear grip
Usable range: up to 2.5 degrees negative
Symptoms of too much adjustment: more over steer; car feels twitchy in back; tires wear out on inside edge; less breakaway warning when limit is exceeded.
Old Feb 11, 2010 | 11:46 AM
0r30kid's Avatar
Thanks for the info dela.
Old Feb 11, 2010 | 11:54 AM
Troubler's Avatar
heres the
P/N 90188-SCC-A00
Do you know how much -/+ camber these bolts allow?
I really haven't looked at the car and which bolts you are talking about, so if the answer would be obvious if I went and looked, just tell me to take a hike!
Old Mar 26, 2010 | 05:19 PM
strmslvrfit's Avatar
+1 on this question, i was looking at the spc camber bolts and it goes up to 1.75 degrees, how much do the civic si bolts do? and are there any other bolts that would give more camber?
Old May 19, 2010 | 12:37 PM
j6kwok's Avatar
I still can't seem to get the camber bolts from my local dealership here in Toronto Ontario Canada, can anyone help me out by pointing out the part number on Bernardi Parts?
My dealership said although that is a Honda part number they don't recognize it in their system.
lastly, since I'm lowered on Eibach Pro-Kit will the negative camber make that much of a difference? Is it necessary to get the camber bolts to get the alignment right? Just wondering since the rear is not fixable already.
Any help is greatly appreciated thanks
Old May 25, 2010 | 11:42 PM
Fitabuloussss's Avatar
Order it at honda parts unlimited, that is where i ordered it from. Haven't installed it yet, so don't know the result
Old Jul 16, 2010 | 02:15 AM
thefit09's Avatar
Would also like to know.
Old Sep 21, 2010 | 05:24 PM
ghettoboy247's Avatar
with buddy club c/o's and oem honda camber bolts, i've gone up to 4.2 but haven't tried to max it out yet
Old Sep 22, 2010 | 02:10 AM
j1nNju1c3's Avatar
heres the
P/N 90188-SCC-A00
Is this the right one BOLT, FLANGE (14X57.3): Honda Parts | Acura Parts | OEM Automotive Parts and Accessories
Just wanted to double check before I buy!
