replacement filter for mishimoto intake
Old Feb 13, 2010 | 09:17 PM
413FIT's Avatar
So its time to replace my filter on my mishimoto intake due to its all rusty and nasty. I have been reading through KN's charts and i cant seem to find one the same size. Anyone replace theirs yet? Also anyone else have a problem with the filter rubbing on the factor intake mounting bracket?
Old Feb 13, 2010 | 11:32 PM
Fitting's Avatar
My filter is still good with a bit of rusting.
Replacement wise you can go with any brand of conical filter.
Just make sure the inlet size is the same.
Only complain of rubbing I'm aware is with the radiator hose.
Old Feb 14, 2010 | 12:58 AM
413FIT's Avatar
yea i was goin through kn's website but it got a litttle over whelming with all the choices
Old Feb 14, 2010 | 01:27 AM
J_L's Avatar
J_L
I've been wondering what to use too, gotta measure it tomorrow and see if a K&N makes something close. I want a blue replacement though...
Old Feb 14, 2010 | 02:31 AM
Fitting's Avatar
How many miles do you guys have on your filter to need replacing?
I thought the filter was reuseable.
Anyway, if you don't want to deal with oiling then maybe use an AEM oiless filter.
Old Feb 14, 2010 | 11:32 AM
413FIT's Avatar
i've got 30k on mine...i want the same tappered cone style but kn doesnt make one small enough
Old Feb 15, 2010 | 09:30 AM
CarbonF1B3R's Avatar
Couldn't you simply use the intake cleaner, and then oil it like any other filter?
Old Feb 15, 2010 | 10:57 AM
413FIT's Avatar
possibly, but my issue is that its all rusted up and looks like shit
Old Feb 15, 2010 | 02:00 PM
Well... if anyone asks, just say "Function over Form"
Old Mar 13, 2010 | 12:03 AM
Fitting's Avatar
Replaced mine with a K&N. I used a 4" long one for a bit more flow and it barely fit. Got mine off of ebay from Summit Racing. There're others that are somewhat the same size as the one I use. There's one that's about the same size as the Mishimoto but inlet is only 2.75".
Old Mar 13, 2010 | 09:22 AM
413FIT's Avatar
you wouldnt happen to know the part number on the kn?
Old Mar 13, 2010 | 08:03 PM
Fitting's Avatar
PN# KNN-RU-3700
Be forewarn it's a very tight fit.
I had to shove it as far back on the cf chamber as I could to get it to fit.
Don't get anything over 4" long.
Now I've to buy a new breather to match
Old Jan 5, 2013 | 10:14 PM
jazn's Avatar
So what size is the inlet?! Ahhhhhh nobody states this!!
Old Mar 21, 2013 | 12:18 PM
riff42's Avatar
Any idea what the MAF sensor connection is? Screw on? Standard size?
Old Mar 22, 2013 | 03:27 AM
loudbang's Avatar
That is a GD there is NO maf sensor on GDs.
Old Mar 22, 2013 | 09:18 AM
riff42's Avatar
A what on a what???
I was told it was a IAT, not a MAF. I want to design my own system, and need to know what the connection is also. I don't have the car here most of the time, so I can't just yank and check.
Old Mar 23, 2013 | 01:08 AM
loudbang's Avatar
What year is your Fit. 2007-2009 GD 2010 --- GE. Or just pop your hood and look at your VIN number it will have GD or GE in the first part.
GD IAT slides in a rubber grommet friction fit.
GE MAF is held in with two screw fasteners.
Old Mar 23, 2013 | 09:18 AM
riff42's Avatar
2008. Those aren't generations are they? I thought it First Gen stopped in 2008.
Either way, still good to know. Tubes are easy to make, threads are not.
zymo
Mar 26, 2011 12:34 PM
GoFits
Sep 12, 2010 09:54 AM
Blueputtputt
Sep 28, 2009 12:11 PM
Red Diablo
Aug 4, 2009 04:42 PM
sLiVeRwOrM
Mar 28, 2007 02:36 PM
