What do you guys think?
Old Feb 13, 2010 | 10:44 PM
mugenfit79's Avatar
I am getting new wheels next week and they are going to be 16X7 40mm offset. I am lowered on tanabe gf210 which is not to low. I think my rims right now are to tucked into the wheel well being at 42mm. I want to give it a better more aggressive look so I want to add some spacers. What sizes should I be looking at? I was thinking 5mm in front and 10mm spacers in rear. Will that make a difference or is to minimal. I am not looking into going crazy with the offsets. I would go as far as just rolling my fenders but would like to avoid it. thanks!
Old Feb 15, 2010 | 12:17 AM
Fitting's Avatar
If you stay on stock wheel studs then 5mm spacers is the max you can go. With 5mm your offset will be down to 35 and that should be pretty flush. You will need to roll the fenders then.
If you can get wheels with the offset you want it would save you work with the spacers.
Old Feb 15, 2010 | 05:32 PM
mugenfit79's Avatar
Thanks man. I will try and see how 5mm will work all around....
bpyoung83
Apr 20, 2015 06:16 PM
liverpoolfcfan
Mar 29, 2012 08:01 PM
jnesselroad
14
Mar 5, 2012 05:24 PM
grooveface
May 25, 2011 08:06 PM
drock305
Jan 6, 2010 08:29 AM
