what wheel spec is best?
Old Feb 14, 2010 | 12:33 AM
jazz_do_it's Avatar
I'm looking to changing my set of wheeLs to a bit bigger rims like 16's. .
i don't wanT those that goes out of the fender to avoid getting much dirt and mud on the sides, and also i am planning to drop it down real low and i dont want to have rubbing issues when i do so.
What rim width and offset would you guys suggest?
I dont know much abouT these stuffs so i would much appreciate everybody's heLp.
Thankz in advance. .
Old Feb 14, 2010 | 08:59 AM
GTornado's Avatar
I think this really depends on your engine and how much performance you need. If you have the 1.3 iDSI engine, you will be happy with 195mm tire width.
Other than that, I'd suggest 7x16 or 7.5x16 +40 on 205/45/16 or 205/40/16. Maybe you can check out the tires and wheels forums on this board, there are a lot of pictures concerning these sizes.
Old Feb 14, 2010 | 09:09 AM
Type 100's Avatar
16x6.5 or 16x7 will be enough as long as you make sure you get +45 offset or higher. +42 offset is pushing it already but can still fit.
I run 16x7 wheels with +45 offset, shod with 205/45R16 rubber. No rubbing at all.
08_vbp_fit
Dec 16, 2016 01:56 PM
tokenasianguy69
13
Sep 2, 2010 01:11 PM
korky
Apr 22, 2008 05:24 PM
MarkB
Apr 16, 2008 04:43 PM
SYMBIOTIX
Mar 14, 2008 08:05 AM
