How to remove the welded nut?
Old Feb 14, 2010 | 01:13 AM
GD3IsCool's Avatar
Guys, i really need some help on this. I was installing a new muffler, so i took the OEM muffler off and ready to put the new one on. But when i was screwing the spring bolts between the b-pipe and the muffler, one was screwed in perfectly, but the other one just doesn't screw in. So i check what is going on, then i realize that the thread of one of the welded nut on the b-pipe was damaged. So i guess i need to somehow remove that welded nut and replace it with a new one? Please lead me through this, thanks.
Old Feb 14, 2010 | 02:29 AM
Fitting's Avatar
Dremel tool with a cutting wheel will do it.
Old Feb 14, 2010 | 04:15 AM
Hootie's Avatar
Try to repair the thread with a die first; then if the nut does not screw on, cut it with a dremel tool like Fitting suggested.
Old Feb 15, 2010 | 05:52 PM
GD3IsCool's Avatar
what is a die? i never know how it looks like. lol
anyone can provide me with a picture or something?
Old Feb 15, 2010 | 06:39 PM
fit2bking's Avatar
These are taps, they will cut new threads. You can use the right size tap to clean out
your stripped threads, if its really bad, then you go one size larger, and get a new bolt.
Old Feb 15, 2010 | 07:12 PM
Erik's Avatar
Originally Posted by fit2bking
These are dies, they will cut new threads. You can use the right size die to clean out
Just to clarify this discussion, those are taps. As described, they will cut clean threads in the nut. Use a light oil and slowly run them through the buggered nut.
A die cuts threads on a piece of smooth stock. Dies look like this:
Old Feb 16, 2010 | 01:27 AM
GD3IsCool's Avatar
Thanks a lot for the info.
Now i gotta find where i can buy those.
Old Feb 16, 2010 | 08:02 AM
Selden's Avatar
Harbor Freight has them on sale this week:
Old Feb 19, 2010 | 12:59 AM
GD3IsCool's Avatar
after visiting few auto stores, i have finally bought the tap and fixed my nut. THANKS EVERYONE!
odin3332
May 1, 2017 04:03 PM
Yakkter
Mar 16, 2014 10:01 AM
kirinzon
May 17, 2011 10:48 AM
Chris901202
European Fit Forums & Clubs
Sep 15, 2009 01:16 AM
fithouston
15
Apr 4, 2007 12:29 PM
