Yes! more issues
Old Feb 15, 2010 | 02:58 PM
MNfit's Avatar
Yes! more issues
My newest problem is under full throttle and higher RPMs, like 5K and up the check engine light will flash. When I let off after a bit it will stop. Twice it has given me 2 codes both P0000? and once P0404. I have all the upgrade you can have for the AT Fits. The car also backfires when Im really on it and the car shifts.
I dont know if this is all to do with the EGR valve or not, I have tried cleaning it twice now and am thinking of tyring to replace it, but for $130 im not sure.
Old Feb 21, 2010 | 01:23 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Its the plugs. A flashing CEL is a misfire. Check the gap, gap them down to .028 -.030
Old Feb 22, 2010 | 08:20 PM
MNfit's Avatar
I have those one plugs that kraftwerks sells
Old Feb 24, 2010 | 07:19 PM
Texas Coyote's Avatar
It was leonines opinion that the IK22 plugs were to cold to use on his car due to fouling problems..... He had the manual transmission S/C on an automatic car and I believe he lived in the Chicago area..... I had a BMW motorcycle than ran great with colder plugs until the temperature go down around the freezing mark and then they would foul.... I believe that you have the I/C on your car and that could be contributing to your car running to cool and causing fouling along with low temperature.
Old Feb 25, 2010 | 12:26 PM
OJRKraftWerks's Avatar
Former Vendor
You should use the one step colder plugs in tough conditions. Running them around in Minnesota winter at low speed is not what we recommended them to do.
We recommend the IK22 to the high performance driver that runs their cars hard and wants maximum performance in extreme conditions.
-Oscar Jr.
Old Feb 28, 2010 | 07:01 PM
SleepyNyte's Avatar
He said his problem was when he was at full throttle, only above 5K, not when he is daily driving, or when he first starts up the car.
Old Feb 28, 2010 | 07:21 PM
dewthedew's Avatar
-Oscar Jr.
He justed stated hes running those.
Old Feb 28, 2010 | 08:01 PM
keepitpg's Avatar
i love college
^^ he's stating what the plugs are geared towards.. meaning that mnfit might be getting hurt by using them, causing a cel because he's not "running his car hard in extreme conditions"
Old Feb 28, 2010 | 08:37 PM
MNfit's Avatar
The car does just fine with half throttle. Its when I go all out with full throttle and get it close to red line that the CEL will start to flash. Im wondering if my MAP sensors is maybe going out? The TMIC is not installed yet and I know the spark plugs are not the issue.
searching around I cant find any thing that tells me what P0000 means. I also noticed when I just turn the car on, with out starting it. The CEL will flash 5 times then turn off. For othere Honda's that is a MAP sensor.
Old Feb 28, 2010 | 09:00 PM
im the fit's Avatar
I was having the same problem...the car feels like its fuel cutting around 5k only at full throttle. it might be a ignition cut?
Old Feb 28, 2010 | 09:08 PM
MNfit's Avatar
did you find a solution
Old Feb 28, 2010 | 09:17 PM
im the fit's Avatar
No but it hasnt been doing it in a while. What injectors are you using?
Old Feb 28, 2010 | 09:24 PM
MNfit's Avatar
the 195cc that KW sells
Old Feb 28, 2010 | 09:49 PM
im the fit's Avatar
Hmmm............?
Old Feb 28, 2010 | 11:23 PM
thefit09's Avatar
I'll pitch in here, I didn't check the code but I had the flashing CEL when I was spraying nitrous on my GE. It only happened in the higher rpms, but I attributed it to an over supply of fuel and the computer cutting out fuel supply to keep it from backfiring.
With all that ya'll are saying though, it might have been an error with my sensor (MAF in my case) because I had the nozzle spraying onto the sensor like a dumbass. All I had to do was unplug and replug the sensor and the CEL went off (it went from flashing to solid after I restarted the car).
One final thing, I have ZEX cold plugs on my car.... if that matters.
Old Feb 28, 2010 | 11:42 PM
Koi's Avatar
Koi
My MIL flashes a few times and goes away like yours. Not throwing any codes or having misfires here though.
Old Mar 13, 2010 | 02:49 PM
MNfit's Avatar
Looks like I found what the CEL was. I dropped my car off at the shop last saturday. While it was on the Dyno the car would not rev past 3K, it would go into limp mod. A bit of dinking around they figured out it was the MAP sensor (kind of what I thought)
So basically if you get a CEL under full throttle and high RPMs it a good idea to look at the MAP sensor.
Old Mar 16, 2010 | 11:57 PM
FELIXY69's Avatar
-Oscar Jr.
i love the plugs
and have also noticed problems with them when it's 2degrees celsius or lower (Vancouver Winter) at low rmp (2k-2.5k) it will notice it being a little rough....
now summer is here....the car drives so much better then other plugs
Old May 19, 2010 | 03:19 PM
da9r00d's Avatar
im having the same problem, i took off the Map stabilizer and the car runs fine
Old May 19, 2010 | 03:20 PM
da9r00d's Avatar
im having the same problem, i changed the MAP sensor and the KWSC MAP stabilizer... No fix. i took off the Map stabilizer and the car runs fine
