Help, My horn and Cruise don't work!
Old Mar 13, 2010 | 11:12 PM
GD3IsCool's Avatar
Long story short, i took off my steering wheel for a stupid reason (too stupid that i feel ashamed to say out) When i installed the steering wheel back, i connected the 2 harness back, one was yellow, and one was black with white connector. Afterward, i realized my horn and cruise BOTH do not work anyone can help me with this? Have been driving around without a horn for weeks. THANKS A LOT.
Old Mar 13, 2010 | 11:17 PM
dewthedew's Avatar
somehwhere along the line the horn/cc harness isnt connected.
Old Mar 13, 2010 | 11:18 PM
GD3IsCool's Avatar
which wire is that? the one with the white connector?
Old Mar 13, 2010 | 11:29 PM
dewthedew's Avatar
its a few wires in a connector...
Old Mar 13, 2010 | 11:36 PM
GD3IsCool's Avatar
How can i check and connect them back? Open up the connector? Can it be opened though? thanks.
Old Mar 14, 2010 | 04:27 PM
jcuecker's Avatar
There are two connections that you may have to check. One is the white connector directly under the airbag. This is a white connector that plugs into the steering coil. There is another connector on the back of the coil (the same white connector). You can see this connector by removing the top plastic cover on the steering column.
Old Mar 17, 2010 | 12:46 AM
GD3IsCool's Avatar
I opened up the top plastic steering column cover, and checked that white connector is properly connected. So, now im assuming its the fuse problem? anyone knows the fuse number for that? (it controls both the horn and my cruise control button)
Old Mar 18, 2010 | 10:28 PM
GD3IsCool's Avatar
anyone knows? any idea? im driving without airbag.
Old Apr 16, 2010 | 10:51 PM
Spooling's Avatar
did you reconnect the ground?
Hobbaswaggle
Jan 12, 2015 04:52 PM
hybridctr
Sep 20, 2012 11:01 PM
dewthedew
Jan 7, 2010 12:41 AM
CrystalFiveMT
Nov 6, 2008 12:55 AM
guailifit
Jul 3, 2008 07:25 PM
