what maintenace do i need
Old Mar 14, 2010 | 09:37 PM
Darkhope's Avatar
I'm kinda a newbie to cars. Can someone tell me what type of maintenance i should do and the time interval for them? I just did my first oil change in a year with my mileage at 2700. A friend told me I should do a oil change within 6 months or 3k whichever comes first. So it would be great if someone can point me in the right direction so I can beware of the type of maintenance that needs to be done in the future as my mileage increase.
Old Mar 15, 2010 | 09:19 PM
Carbuff2's Avatar
You should follow the Maintenance Minder...except that for low mileage, little-used cars, oil should be changed at least once a year (per Honda).
If you want an idea of other required services, go to the Honda Ownerlink and say that you have a 2006 CRV or 2005 Civic. Then you can look at the maintenance requirements for those non-MM cars.
Remember that there are both Mileage and Time requirements for most services.
Old Mar 15, 2010 | 10:06 PM
Selden's Avatar
Read the owner's manual. You should be able to do oil and filter changes yourself, as well as tire rotations. I like to change brake fluid more frequently than recommended, never longer than 24 months between changes. A vacuum pump (e.g., MityVac) makes brake fluid changes a 1-person operation; see: Brake bleeding. If you're a newbie to cars, take it to the dealer for anything else, or find a knowledgeable person to learn from.
Old Mar 16, 2010 | 08:51 PM
Darkhope's Avatar
Thanks for your input.
fitchet
Sep 18, 2022 08:58 PM
lason
Apr 23, 2011 07:58 PM
tietack
Aug 24, 2010 01:55 PM
kinosh
Mar 18, 2009 08:31 AM
Bounty Hunter
Feb 20, 2007 02:00 PM
