Put some wheels and tires on my GE. 205/60/15
Old Apr 7, 2010 | 08:13 AM
axe's Avatar
axe
Wheels: Drag DR-23, 15x6.5
Tires: Goodyear Eagle GT, 205/60/15
Springs: Eibach Pro-Kit, 1.2" F / 1.4" R
The difference in grip is tremendous. The car comes stock with 175/75/15s on 15/5.5" wheels. The extra 30mm of (stickier) rubber grips relentlessly, and the springs cut down on the car's ample body roll. There's almost too much tire for the car, I can barely get the ABS to kick in :P
Excuse the crappy pics, I was losing light...
Old Apr 11, 2010 | 06:46 PM
Klasse Act's Avatar
Question
First off I like your avatar, Rush "Signals", very cool Because your car is lowered though I wonder why you went with such a thick sidewall profile tire?
BTW, nice choice of rims
Old Apr 12, 2010 | 07:42 AM
axe's Avatar
axe
It was a combination of a few factors... i wanted 15s, so I had to get a pretty big tire in any case. Technically the correct size would have been a 205/55 (rather than 60 series) but the 60s were about 40% cheaper
Old Apr 13, 2010 | 01:20 PM
beangrower's Avatar
wow...looks like ur ready to rally. i like it.
Old Apr 13, 2010 | 08:09 PM
JJIN's Avatar
^ exactly what i was thinking. wrc style tuning!
Old Apr 13, 2010 | 08:38 PM
Type 100's Avatar
I was about to say the tires were too tall...until I realized they were 15s.
Nice job, good to know they're paying off well!
Old Apr 13, 2010 | 08:51 PM
Perrenoud Fit's Avatar
I just put a set of Eagle GT's (195/60/15 from Tire Rack+ 20.00 rebate from GoodYear) on my Fit last week and like'n them alot! Sticky-Quiet
Old Apr 13, 2010 | 09:59 PM
misFIT.'s Avatar
axe, do you have light blue tint?
or is that just the lighting in the pictures?
Old Apr 14, 2010 | 05:04 AM
Wongawa's Avatar
Your car looks nice!
Old Apr 14, 2010 | 07:39 AM
axe's Avatar
axe
Looks good! It's nice to have enough sidewall that every pothole doesn't send your pulse racing
No tint at all, I had to edit the pics a bit because they were too dark, that's probably why the windows look so blue.
Old Apr 14, 2010 | 08:25 AM
Texas Coyote's Avatar
You might find a way to check the difference between how fast you are going and the speedometer reading.... The way it looks is amazing.... I really like it a lot, when others see it some may copy the your look.
Old Apr 14, 2010 | 08:49 AM
axe's Avatar
axe
It throws off the speedometer by about 2%, which isn't too bad. According to my GPS it was reading a bit slow with the stock tires, so it's probably spot-on now :P
Old Apr 14, 2010 | 11:20 AM
15" wheels have looked good on every GE I have seen with them.... The tall wheel thing isn't all it is cracked up to be..and the lower bias ratio tires either.
Old Apr 16, 2010 | 10:05 PM
Klasse Act's Avatar
The taller tire is the way to go IMO if your not planning on lowering the car because it fills the wheelwell in for one, gives you a better/safer ride if you live where the roads aren't the best two and three, like your said earlier, its cheaper.
Old Apr 16, 2010 | 11:37 PM
Thumbs up rubb'n 4 me = airshocks 4 the GD3
Hey Axe have any rubbing? The 4th shot looks like the tire is very close to the fender, I got spacers on mine and the taller tire was too much so I'm putting a set of airshocks on. But I like the way the tires are pushed out of the wheel wells w/ the spacer & wouldn't change that The A.S. will provide alot more payload in the back, never could put too much weight back there B4.
UR GE looks great with the tire/wheel setup, take care
Old Apr 19, 2010 | 09:54 AM
axe's Avatar
axe
It does rub a little bit in the front, mostly when turning + braking simultaneously. I pulled the fenders (by hand) about 1/2" which seems to have fixed it. Good thing I didn't get 15 x 7s like I had originally planned
Shaggs2Dope
Oct 12, 2015 12:01 PM
honda_82
May 13, 2011 04:02 PM
Blackbeard
Apr 14, 2011 03:04 PM
circa40
Dec 20, 2010 01:23 PM
PowerHungryFIT
Mar 31, 2009 10:37 PM
