wrapping the coil packs
Old Apr 11, 2010 | 07:21 PM
leonine's Avatar
Can anyone tell me what the best way to wrap the coil packs is? using aluminum foil how far down do i go? cover the top and all the way down till the red rubber tip? Is there a downside to doing this?
Old Apr 11, 2010 | 07:56 PM
dewthedew's Avatar
I would not use aluminum foil! if you are trying to protect them from heat you should google "thermal blanket" and pick up some of that. works great.. I put 3 layer between intake manifold and the valve cover, and I wrapped my header with it.
You could just cut a few peice and cover the tops of the coil packs.
Old Apr 11, 2010 | 11:00 PM
im the fit's Avatar
Same here! thermal blanket is the best!!!
Old Apr 13, 2010 | 10:34 PM
leonine's Avatar
already done that and removed it. Actually rose the intake air temperature with it on. Why no aluminum foil?
Old Apr 13, 2010 | 11:16 PM
im the fit's Avatar
Leave the foil for the kitchen....I cant believe thermal wrap didnt work??
Old Apr 18, 2010 | 04:15 AM
Texas Coyote's Avatar
What kind of IAT readings are most people getting.
phoenity
Nov 15, 2024 12:50 PM
JCLW
Aug 14, 2023 04:41 AM
Mtwalenciak
Dec 23, 2014 10:04 AM
dtgrosse
Jul 17, 2014 01:04 PM
a
Sep 9, 2005 12:37 AM
