Will 17x7 38mm offset fit without rubbing?
Old Apr 17, 2010 | 01:48 AM
khaaymamk's Avatar
Someone in my area has a good deal on a set of work emotion wheels in my area. I know 17x7 works fine, but is will a 38mm offset work without modification? Will I experience rubbing?
Thanks.
Old Apr 17, 2010 | 01:55 AM
DreaMv's Avatar
if you're lowered you probably will if you dont have fender mods or some sort of camber to not rub.
Old Apr 17, 2010 | 02:00 AM
khaaymamk's Avatar
Vehicle is stock.... 2010 model.
Old Apr 17, 2010 | 03:32 AM
vinn's Avatar
You will rub. I had a set of RacingHart C5 17x7 +38 and I couldn't even get it out of the driveway
Old Apr 17, 2010 | 11:03 AM
khaaymamk's Avatar
vinn.... is your car lowered?
Old Apr 17, 2010 | 03:13 PM
MugenAP2's Avatar
All you need is camber!!!!
Old Apr 18, 2010 | 12:25 PM
lilaznphatboy's Avatar
go to your local honda dealership and purchase a $17 '06+ Honda civic SI front camber bolt
Old Apr 19, 2010 | 12:05 AM
j6kwok's Avatar
what's the part number for the front bolt my local Dealership told me they have no clue which one it is and they pulled the diagram and there were 2 one on top and one on the bottom
Old Apr 19, 2010 | 06:06 PM
give this a try...im like 85% sure this is the right P/N: 90188-SCC-A00
Old Apr 21, 2010 | 11:50 PM
j6kwok's Avatar
Thanks for the info. I went to my local dealer in Toronto Ontario and they don't recognize that number, anyway you could possibly help with getting the US or CDN part number they would use at the dealership??
Old Apr 22, 2010 | 12:20 AM
hmmm....idk that was the number i was given but ill do a little more research and get back at you
1904-08-fit-sport
Mar 9, 2010 10:03 PM
Scaldy
May 1, 2009 09:44 PM
allgocrx
Mar 24, 2009 03:33 PM
bebop.fey
Mar 3, 2009 05:53 PM
domk2
Aug 7, 2008 10:19 AM
