Do I need new lug nuts?
Old May 11, 2010 | 10:41 PM
.eL's Avatar
.eL
I just ordered a set of Rota wheels and I was wondering if I'd be able to use my OEM lugs on them for a while.
Are they shaped different? It's been a while since I've used any aftermarket wheel.
If so, what do you recommend?
Old May 11, 2010 | 10:58 PM
im the fit's Avatar
Get new lugs asap! It has to be a big cone shape at the bottom.
Old May 11, 2010 | 11:03 PM
.eL's Avatar
.eL
I'm currently using 99-00 Civic SI wheels with Fit OEM lugs. I'm sure the OEM Fit wheels and the SI wheels are the same but I don't remember which shape they were. The rota wheels, I don't know what they look like.
Does anyone here know whether the Rota wheels would need tapered, ball, or flat lugs? I think the OEM lugs are ball shaped... but I don't really remember.
Old May 11, 2010 | 11:16 PM
cr4zy3lgato's Avatar
well OEM is acorn shaped (ball type) and the aftermarket wheels use tapered seats...
btw it's dangerous to ride with the wrong lug nuts... they could damage your wheel or untighten...
the seat is what's keeping them from untightening
Last edited by cr4zy3lgato; May 11, 2010 at 11:18 PM. Reason: forgot to mention something
Old May 12, 2010 | 12:11 AM
.eL's Avatar
.eL
Can anyone recommend some reasonably priced lug nuts? Closed ended preferably but not necessary.
NO MUTEKI! I broke one of their "keys" before with little effort and getting my lugs off wasn't easy.
After searching, I'm a bit disappointed. The prices of lug nuts has seriously gone up since I last bought some in '04. It's like they've doubled lol.
Old May 12, 2010 | 01:10 AM
.eL's Avatar
.eL
Thinking about these.
Lug Nuts Wheel Adapters Wheel Spacers Lug Bolts
I had something similar to these in black before and I liked that the key went in the lug instead of around it. Would you trust these? lol. I want red lugs btw so those seemed like a good choice. They're cheap and sadly that scares me.
Old May 12, 2010 | 06:42 AM
well after doing some research it seems that all the spline drives have a tendency to have problems, either they round off or the key cracks... as for the ones you posted, i think it would be fairly easy to just stick a tool in them too unbolt them... but idk... just my .02... the safest bolts i've seen so far are the ones with some kind of star pattern...
Old May 12, 2010 | 10:45 AM
score04w's Avatar
i love my buddlyclub open ended i got from evasive. Only bad bad is that they are open ended, but they are pretty inexpensive. I think it was $18 for a pack of 4.
Old May 13, 2010 | 03:34 PM
.eL's Avatar
.eL
Must be nice to think $18x4 is inexpensive lol. I couldn't see myself spending more than $50 for a set.
Old May 14, 2010 | 01:35 PM
score04w's Avatar
i bought them a pair at a time so it didnt seem like that much.
Old May 17, 2010 | 10:45 PM
.eL's Avatar
.eL
That would help if I didn't need them all at once and asap. I might do that later on.
Question for anyone who might know:
Would I torque these lug nuts the same as stock or does something change? I think stock is 90ft/lbs.
Old May 17, 2010 | 11:40 PM
you need too torque them as usual... just don't use an impact wrench...
Nuno Quintelas
Jan 31, 2017 12:42 PM
fiteddy
Jun 26, 2013 04:59 PM
rocketberger
19
Nov 13, 2012 07:30 AM
Lek
Dec 1, 2009 08:40 AM
Fithonda2008
Sep 18, 2008 07:46 PM
